Gapless Events View
xeroiv
Gapless Events View
Post by xeroiv »
Is it possible to have multiple events play back to back in the webui? I have a monitor setup and captured around 150 events, I then selected 10 or so and pressed view. The first event plays but it does not auto advance to the next event from my selection even when I set the playback to gapless. The events that were triggered were of the cause continuous if that has any bearing on this.
A secondary unrelated question: in the live view is there a way to lock the viewing fps to the capture FPS? The capture FPS on my stream is pretty solidly 30 fps, but the view FPS bounces around between 10-20.
Re: Gapless Events View
gapless should work exactly as you describe. I'll have to look into it.
As to your second question, no. It sends images as fast as it can (unless told to do less).
xeroiv
Post by xeroiv »
Ok thanks for looking into the Gapless playback issue. I have tried it on Chrome and Edge with similar results.
Is it possible to setup the API token to be "permanent"? I do not know how I can embed a changing token into my loxone setup or the tinycam android app (I know zmNinja exists, I am testing out ZM against my current setup which is Shinobi and use tinycam for stream monitors).
xeroiv
Post by xeroiv »
iconnor wrote: Mon Apr 04, 2022 10:21 pm gapless should work exactly as you describe. I'll have to look into it.
So after deleting all events and other config tweaks in the system to setup the API the gapless playback works. Now just to figure out how to block all these single frame events...
geraldbrandt
Post by geraldbrandt »
My gapless event do playback continuously if I do camera passthrough. Even with gapless set, I have to press play every event. If I turn off save audio, gapless works again.
