Problem with Disk Percent on v1.37.13
manfzimm
Post by manfzimm »
Hi
I'm running ZM v1.37.13
It is not possible to Purge my (nearly) full disk (96 %).
Storage Area matches default
Disk Percent greater than or equal to 90
End Date/Time is not NULL
When I test by using "list matches" the page display not a single event
When I use the "Debug"-button I get this Information:
SQL SELECT E.*,M.Name AS MonitorName,M.DefaultScale
FROM Monitors AS M INNER JOIN Events AS E ON (M.Id = E.MonitorId)
WHERE
E.StorageId regexp '2' and TRUE /*DiskPercent*/ and E.EndDateTime IS NOT NULL ORDER BY Id ASC LIMIT 10
As you see the SQL-satement does not use the "90" for/*DiskPercent*/.....
Is there a solution ?
Thanx
Manfred
Re: Problem with Disk Percent on v1.37.13
Why would it? Surely it's a variable.
Andyrh
Post by Andyrh »
Be sure the storage area is listed in the filter. Otherwise it only looks at the original storage area.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
manfzimm
Post by manfzimm »
Thanks for responding.
Yes, it is a variable. And disk usage is shown in the control panel STORAGE --> DEFAULT: 96 %
The storage area is also listed in the filter (dropdown --> DEFAULT).
If I delete the line "Disk Percent" and "LIST MATCHES" shows events.
The default limit is 100.
Suggest you try that or even 1000.
moved to the1.37 forum
The Debug button uses different code than the actual filter. What we need \to do here is turn on debugging, restart the filter and check the filter logs to see what the actual SQL is.
