No dropdown for (Monitor, MODECT, etc) see screenshot. Why is this???
I just setup ZM on a small and slow thin client desktop compjuter and for some reason there's no function drop down and I can't change the setting for the camera. What can I do to fix this?
- Screenshot_2022-05-06_14-59-06.png (118.4 KiB) Viewed 636 times
Re: No dropdown for (Monitor, MODECT, etc) see screenshot. Why is this???
That’s the 1.37 development release. Possibly normal.
oh no! Is there a way to go to an older version? Or... is there a way to change the setting. I would like to use MODect.
Modect is equivalent to : Capturing=Always, Analysis=Always, Recording = On Motion
You can go back to 1.36 simply by:
sudo apt-get remove zoneminder
sudo add-apt-repository -r ppa:zoneminder-master
sudo add-apt-repository ppa:zoneminder-1.36
sudo apt-get install zoneminder
It lives! Thanks for the tip. I went ahead and installed 1.34.
