Can't add monitors
Re: Can't add monitors
As I said above, remember to set the video width and height.
I have fixes in proposed. Will likely release 1.36.17 later today.
clipo
Post by clipo »
iconnor wrote: Tue May 31, 2022 4:43 pm I have fixes in proposed. Will likely release 1.36.17 later today.
I've noted the proposed PPA has the fixes and I can confirm that adding monitors is working once again.
The 1.36 PPA currently is still 1.36.16 and not the proposed 1.36.17 if this needs to be pushed through.
One item I have noted is that within the Storage tab the options to adjust the Output Codec and Encoder are missing if this is a change between the versions.
Screenshot at 2022-06-01 10-06-38.png (101.55 KiB) Viewed 1481 times
bkjaya1952
Post by bkjaya1952 »
The problem has been solved in the latest zoneminder 1.36.17-focal1 released today .
Now ,The monitors can be added without any problem .
bkjaya1952
Yes Sir . Now the monitors can be added without any problem in zoneminder 1.36.17-focal1 released today !
Thank you very much for fixing the issue !! :D :D
