ie20 legeek onvif setup
frankz66
Post by frankz66 »
Hello everyone, I would like to configure on zoneminder the possibility of having the control of the camera via onvif or other.
The model is ie20 Legeek . Can anyone help me?
clipo
Re: ie20 legeek onvif setup
Post by clipo »
I've had partial success getting the iegeek i20 camera working on ZM
It should work under the ONVIF but the logs give Error 400 bad command
But if you add the camera as a Reolink RLC-423
with the control address as
user:password@ipaddress:8080
as per the below snip.
using an ONVIF client on an Android phone you can have full control of the camera so the camera is capable of ONVIF so there is an issue with the ZM ONVIF config.
Screenshot at 2022-06-05 10-52-12.png (81.29 KiB) Viewed 7750 times
frankz66
Post by frankz66 »
[quote=clipo post_id=126695 time=1654423048 user_id=13492]
[/quote]
Thank you so much! At the moment I've seen that the turn signals work, but not the preset keys or anything else. You gave me a lot of help, I had lost hope for us! If you have anything else to try, I would be grateful!
clipo
Post by clipo »
Ive managed to fix the continuous movement issue with the Reolink PTZ config.
Place the below code into the /usr/share/perl5/ZoneMinder/Control folder or where ever your distro keeps the config files and name the file as ieGeek.pm
Then you need to make your own profile inside ZM and reference this ieGeek file, if you just look at the other configs you will start to see how it is formatted..
I'll add this to Github when I get time.
Screenshot at 2022-06-09 21-57-13.png (56.16 KiB) Viewed 7695 times
Screenshot at 2022-06-09 21-55-19.png (201.04 KiB) Viewed 7695 times
Screenshot at 2022-06-09 21-55-44.png (26.96 KiB) Viewed 7695 times
# Basic ZoneMinder ieGeek IE20 ONVIF IP PTZ Camera Control Module 9-June-2022
# By Clipo (ZoneMinder Forums)
# This file is based up on the Reolink IP Control Module 2016-01-19
# Copyright (C) 2016 Chris Swertfeger
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
# This module contains the first implementation of the ieGeek ONVIF IP camera control
# protocol
package ZoneMinder::Control::ieGeek;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
our %CamParams = ();
# ieGeek ONVIF IP Control Protocol
# The ieGeek camera support ONVIF in a limited way with
# this script sends ONVIF style commands and may work with other cameras
# that require authentication
# The script was developed against an IE20 Camera.
# Basic preset functions are supported only.
# On ControlAddress use the format :
#   USERNAME:PASSWORD@ADDRESS:PORT
#   eg : admin:pass@10.1.2.1:8080
# ieGeek cameras use port 8080 by default
# The Auto Stop Timeout field.
# Recommend starting with a value of 1 second, and adjust accordingly.
use Time::HiRes qw( usleep );
use MIME::Base64;
use Digest::SHA;
use DateTime;
my ($username,$password,$host,$port);
sub open
    my $self = shift;
    $self->loadMonitor();
    # Extract the username/password host/port from ControlAddress
    if( $self->{Monitor}{ControlAddress} =~ /^([^:]+):([^@]+)@(.+)/ )
    { # user:pass@host...
      $username = $1;
      $password = $2;
      $host = $3;
    elsif( $self->{Monitor}{ControlAddress} =~ /^([^@]+)@(.+)/ )
    { # user@host...
      $username = $1;
      $host = $2;
    else { # Just a host
      $host = $self->{Monitor}{ControlAddress};
    # Check if it is a host and port or just a host
    if( $host =~ /([^:]+):(.+)/ )
      $host = $1;
      $port = $2;
    else
      $port = 80;
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $msg = shift;
    my $content_type = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    my $server_endpoint = "http://".$host.":".$port."/$cmd";
    my $req = HTTP::Request->new( POST => $server_endpoint );
    $req->header('content-type' => $content_type);
    $req->header('Host' => $host.':'.$port);
    $req->header('content-length' => length($msg));
    $req->header('accept-encoding' => 'gzip, deflate');
    $req->header('connection' => 'close');
    $req->content($msg);
    if ( $res->is_success ) {
        $result = !undef;
    } else {
        Error("After sending PTZ command to $server_endpoint, camera returned the following error:'".$res->status_line()."'" );
    return $result;
sub getCamParams
    my $self = shift;
    my $nonce;
    for (0..20){$nonce .= chr(int(rand(254)));}
    my $mydate = DateTime->now()->iso8601().'Z';
    my $sha = Digest::SHA->new(1);
    $sha->add($nonce.$mydate.$password);
    my $digest = encode_base64($sha->digest,"");
    my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope">
    	<s:Header>
	<Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
	<UsernameToken>
	<Username>'.$username.'</Username>
	<Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password>
	<Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce>
	<Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created>
	</UsernameToken>
	</Security>
	</s:Header>
	<s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
	<GetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl">
	<VideoSourceToken>000</VideoSourceToken>
	</GetImagingSettings>
	</s:Body>
	</s:Envelope>';
    my $server_endpoint = "http://".$self->{Monitor}->{ControlAddress}."/onvif/imaging";
    $req->header('content-type' => 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/imaging/wsdl/GetImagingSettings"');
    $req->header('Host' => $host.":".$port);
    $req->header('connection' => 'Close');
        # We should really use an xml or soap library to parse the xml tags
        my $content = $res->decoded_content;
        if ($content =~ /.*<tt:(Brightness)>(.+)<\/tt:Brightness>.*/) {
            $CamParams{$1} = $2;
        if ($content =~ /.*<tt:(Contrast)>(.+)<\/tt:Contrast>.*/) {
    else
        Error( "Unable to retrieve camera image settings:'".$res->status_line()."'" );
#autoStop
#This makes use of the ZoneMinder Auto Stop Timeout on the Control Tab
sub autoStop
    my $self = shift;
    my $autostop = shift;
    if( $autostop ) {
        Debug( "Auto Stop" );
        my $cmd = 'onvif/PTZ';
        my $nonce;
        my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope">
		<s:Header>
		<UsernameToken>
		</UsernameToken>
		</Security>
		</s:Header>
		<ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl">
		<ProfileToken>000</ProfileToken>
		<Velocity>
		<PanTilt x="0" y="0" xmlns="http://www.onvif.org/ver10/schema"/>
		</Velocity>
		</ContinuousMove>
		</s:Body>
		</s:Envelope>';
    	my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/ContinuousMove"';
        usleep( $autostop );
        $self->sendCmd( $cmd, $msg, $content_type );
# Reset the Camera
sub reset
    Debug( "Camera Reset" );
    my $self = shift;
    my $nonce;
    my $cmd = "";
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	<SystemReboot xmlns="http://www.onvif.org/ver10/device/wsdl"/>
	</s:Body>
	</s:Envelope>';
    my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver10/device/wsdl/SystemReboot"';
#Up Arrow
sub moveConUp
    Debug( "Move Up" );
    my $self = shift;
    my $nonce;
    		<s:Header>
		<UsernameToken>
		</UsernameToken>
		</Security>
		</s:Header>
		<Velocity>
		<PanTilt x="0" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/>
		</Velocity>
		</ContinuousMove>
		</s:Body>
		</s:Envelope>';
    #AutoStop Commnented out to give fine control
    #$self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
    Debug( "Move Down" );
    my $self = shift;
    my $nonce;
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	><Velocity>
	<PanTilt x="0" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
#Left Arrow
sub moveConLeft
    Debug( "Move Left" );
    my $self = shift;
    my $nonce;
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	<Velocity>
	<PanTilt x="-0.49" y="0" xmlns="http://www.onvif.org/ver10/schema"/>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
#Right Arrow
sub moveConRight
    Debug( "Move Right" );
    my $self = shift;
    my $nonce;
     	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	<Velocity>
	<PanTilt x="0.49" y="0" xmlns="http://www.onvif.org/ver10/schema"/>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
#Stop
sub moveStop
    Debug( "Move Stop" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header>
    <UsernameToken>
    </UsernameToken>
    </Security>
    </s:Header>
    <Velocity>
    </Velocity>
    </ContinuousMove>
    </s:Body>
    </s:Envelope>';
1;
frankz66
Post by frankz66 »
[quote=clipo post_id=126801 time=1654808824 user_id=13492]
[code]# ==========================================================================
# protocol
use 5.006;
use strict;
use warnings;
use MIME::Base64;
use Digest::SHA;
use DateTime;
sub open
my $self = shift;
$username = $1;
$password = $2;
$host = $3;
{ # user@host...
$username = $1;
$host = $2;
$host = $1;
$port = $2;
else
$port = 80;
use LWP::UserAgent;
sub printMsg
my $self = shift;
my $msg = shift;
sub sendCmd
my $self = shift;
my $cmd = shift;
my $msg = shift;
my $result = undef;
$result = !undef;
} else {
return $result;
sub getCamParams
my $self = shift;
my $nonce;
<s:Header>
<Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/ ... xt-1.0.xsd">
<UsernameToken>
<Password Type="http://docs.oasis-open.org/wss/2004/01/ ... </Password>
<Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/ ... ).'</Nonce>
<Created xmlns="http://docs.oasis-open.org/wss/2004/01/ ... '</Created>
</UsernameToken>
</Security>
</s:Header>
</s:Body>
</s:Envelope>';
$req->header('content-type' => 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/imaging/wsdl ... ngSettings"');
else
#autoStop
sub autoStop
my $self = shift;
if( $autostop ) {
my $nonce;
<s:Header>
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
<Velocity>
</Velocity>
</ContinuousMove>
</s:Body>
</s:Envelope>';
# Reset the Camera
sub reset
my $self = shift;
my $nonce;
my $cmd = "";
<s:Header>
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
</s:Body>
</s:Envelope>';
#Up Arrow
sub moveConUp
Debug( "Move Up" );
my $self = shift;
my $nonce;
<s:Header>
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
<Velocity>
</Velocity>
</ContinuousMove>
</s:Body>
</s:Envelope>';
#Down Arrow
sub moveConDown
my $self = shift;
my $nonce;
<s:Header>
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
><Velocity>
</Velocity>
</ContinuousMove>
</s:Body>
</s:Envelope>';
#Left Arrow
sub moveConLeft
my $self = shift;
my $nonce;
<s:Header>
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
<Velocity>
</Velocity>
</ContinuousMove>
</s:Body>
</s:Envelope>';
#Right Arrow
sub moveConRight
my $self = shift;
my $nonce;
<s:Header>
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
<Velocity>
</Velocity>
</ContinuousMove>
</s:Body>
</s:Envelope>';
#Stop
sub moveStop
my $self = shift;
my $nonce;
<UsernameToken>
</UsernameToken>
</Security>
</s:Header>
<Velocity>
</Velocity>
</ContinuousMove>
</s:Body>
</s:Envelope>';
1;
[/code]
[/quote]
Thank you so much for your contribution, when I will apply the changes first.
frankz66
Post by frankz66 »
I tried to create and enter the code as per your instructions, but I don't find myself "ieGeek.pm" in the choice menu.
clipo
Post by clipo »
The ieGeek wont appear by its self the above scrip is the background control "protocol" file.
Once you have the control "protocol" file you now need to manually make the "Control Type" in the database by pressing the "Edit" button as shown in the first screen shot in my previous post.
You will then be give the menu in the second screen shot in my previous post, you can then either edit one of the existing profiles or make a new one by pressing the "+" button and then enter the "Name" of your choice but enter the "Protocol" name as ieGeek as per the file name of the "protocol" file you made at the start and choose the check boxes required for the control types similar to those shown in this post.
This will make an entry in the database and give this as an option for you to select under the Control tab.
Screenshot at 2022-06-09 21-56-09.png (40.25 KiB) Viewed 7647 times
Screenshot at 2022-06-09 21-55-58.png (25.99 KiB) Viewed 7647 times
garyc
Post by garyc »
Thank you so much for this post.
I received my IE50 in the post today and started playing to get it working in ZM. Took a while but was then stumped concerning the control functions (fisrt camera with such functionality after all these years with an old Y-Cam that has just had its wifi fail after 15+ years on the garage wall...).
Took me a while to understand the instructions and to realise, I think, that this is still embyonic and provides only pan and tilt functions but hey, it works a treat on the IE50.
The Android App for teh camera has presets, gain control and a host of other stuff and the camera has a digital zoom (IE20 too and IE30 an optical one). Do you think that at some point a comprehensive profile and protocol will be incorporated into ZM, or at least able to be created DIY as in this thread?
Thanks again.
clipo
Post by clipo »
garyc wrote: Fri Jul 01, 2022 3:41 pm Do you think that at some point a comprehensive profile and protocol will be incorporated into ZM, or at least able to be created DIY as in this thread?
I posted the below code to the Zoneminder Git but after reading other peoples submits on this topic I removed the code as I dont think the ZM admins will incorporate it into the main builds as they are looking for a 100% working ONVIF
The below code is my final version for the ieGeek ie20 camera, I tried to get presets working and some of the other features but the ZM code and or the built in ONVIF functions are not 100% compliant so it would always fail.
# protocol
use 5.006;
use strict;
use warnings;
use MIME::Base64;
use Digest::SHA;
use DateTime;
sub open
    my $self = shift;
      $username = $1;
      $password = $2;
      $host = $3;
    { # user@host...
      $username = $1;
      $host = $2;
      $host = $1;
      $port = $2;
    else
      $port = 80;
    use LWP::UserAgent;
sub printMsg
    my $self = shift;
    my $msg = shift;
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $msg = shift;
    my $result = undef;
        $result = !undef;
    } else {
    return $result;
sub getCamParams
    my $self = shift;
    my $nonce;
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	</s:Body>
	</s:Envelope>';
    else
#autoStop
sub autoStop
    my $self = shift;
    if( $autostop ) {
        my $nonce;
		<s:Header>
		<UsernameToken>
		</UsernameToken>
		</Security>
		</s:Header>
		<Velocity>
		</Velocity>
		</ContinuousMove>
		</s:Body>
		</s:Envelope>';
# Reboot the Camera
sub reboot
    Debug( "Camera Reboot" );
    my $self = shift;
    my $nonce;
    my $cmd = "";
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	</s:Body>
	</s:Envelope>';
#Up Arrow
sub moveConUp
    Debug( "Move Up" );
    my $self = shift;
    my $nonce;
    		<s:Header>
		<UsernameToken>
		</UsernameToken>
		</Security>
		</s:Header>
		<Velocity>
		</Velocity>
		</ContinuousMove>
		</s:Body>
		</s:Envelope>';
#Down Arrow
sub moveConDown
    my $self = shift;
    my $nonce;
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	><Velocity>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
#Left Arrow
sub moveConLeft
    my $self = shift;
    my $nonce;
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	<Velocity>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
#Right Arrow
sub moveConRight
    my $self = shift;
    my $nonce;
     	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	<Velocity>
	<PanTilt x="0.5" y="0" xmlns="http://www.onvif.org/ver10/schema"/>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
#Stop
#The ieGeek implimentaion of ONVIF seems to not support the Stop command so a zero motion contious move command is sent.
sub moveStop
    my $self = shift;
    my $nonce;
    	<s:Header>
	<UsernameToken>
	</UsernameToken>
	</Security>
	</s:Header>
	<Velocity>
	</Velocity>
	</ContinuousMove>
	</s:Body>
	</s:Envelope>';
1;
garyc
Post by garyc »
Thanks. At least I am up and running with basic functionality...
clipo
Post by clipo »
Update for ZM 1.37.66
Screenshot at 2025-05-25 14-35-06.png (58.94 KiB) Viewed 680 times
