I updated my ZM to 1.36.15 and ever since then it has been runnning slow and I find alot of my footage doesnt play back.
Checking the error logs I am getting alot of errors of "sock does not exist...ensure that CGI is enabled".
Reading up on this I found that it appears to be related to ZM_PATH_ZMS
Doing a cat /etc/zm/conf.d/01-system-paths.conf I can see that ZM_PATH_ZMS=/zm/cgi-bin/nph-zms but and if I look at the apache files the alias for /ZM is "/usr/share/zoneminder/www" and when I look in /usr/share/zoneminder/www I can see there is no cgi-bin folder.
When I run "sudo find / -type d | grep "cgi-bin"" all it returns is this:
/usr/lib/zoneminder/cgi-bin
/usr/lib/cgi-bin
/usr/lib/cups/cgi-bin
/usr/share/doc/libsoap-wsdl-perl/examples/cgi-bin
/usr/share/doc/popularity-contest/examples/cgi-bin
I am not sure on what to do to resolve this issue.
Any help would be great.
Sock does not exist filling logs
Re: Sock does not exist filling logs
It's in a ScriptAlias on mine.
Have a look here https://github.com/ZoneMinder/zoneminde ... inder.conf
1.36.15 had some issues, this being one. Upgrade to 1.36.18/19.
