purgewhenfull not working with DiskPercent
davic
Post by davic »
HI,
with the debug of PurgeWhenFull I obtain :
"SQL SELECT E.*,M.Name AS MonitorName,M.DefaultScale
FROM Monitors AS M INNER JOIN Events AS E ON (M.Id = E.MonitorId)
WHERE TRUE /*DiskPercent*/ and E.Archived = '0' and E.StorageId = '1' ORDER BY StartDateTime ASC LIMIT 10"
In the diskpercent miss the parameter ">90%". Tried many conditions but noghing.
thanks
Andyrh
Re: purgewhenfull not working with DiskPercent
Post by Andyrh »
Can you post a picture of the PurgeWhenFull filter?
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
davic
Post by davic »
HI, in the debug image you can see there's not the parameter "90%"
filter debug.jpg (47.99 KiB) Viewed 641 times
It clearly shows DiskPercent.
davic
Post by davic »
Yes, in the SQL shows "DiskPercent" but not "90" and that's why it doesn't work.
Still writing "90%" not works.
I don't think so.
I’m not sure trying to update diskspace in the purge is a good idea. It’s a separate filter.
