Gentoo Compile Problems (solved)
coutts99
Post by coutts99 »
I am trying to install ZoneMinder 1-21.3 from the Gentoo ebuild, but I am hitting this error on compile -:
zm_mpeg.cpp: In member function `void VideoStream::SetupCodec(int, int, int, int, int)':
zm_mpeg.cpp:78: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
zm_mpeg.cpp:88: error: 'struct AVCodecContext' has no member named 'frame_rate'
zm_mpeg.cpp:89: error: 'struct AVCodecContext' has no member named 'frame_rate_base'
zm_mpeg.cpp: In member function `void VideoStream::OpenStream()':
zm_mpeg.cpp:120: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
zm_mpeg.cpp: In destructor `VideoStream::~VideoStream()':
zm_mpeg.cpp:220: error: cannot convert `AVCodecContext**' to `AVCodecContext*' for argument `1' to `int avcodec_close(AVCodecContext*)'
zm_mpeg.cpp: In member function `double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)':
zm_mpeg.cpp:263: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/var/tmp/portage/zoneminder-1.21.3/work/zm-1.21.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/zoneminder-1.21.3/work/zm-1.21.3'
make: *** [all] Error 2
Anyone got any ideas?
cordel
Post by cordel »
I have a small clue where you might look, It is tring to pull functions from ffmpeg libraries and failing. What version of ffmpeg do you have installed?
Regards,
Cordel
rjohanne
I have the same problem, not being able to compile
Post by rjohanne »
I have the same problem of not being able to compile because it "cannot convert `AVCodecContext**' to `AVCodecContext*'" and I am using the latest cvs release of ffmpeg as of Sunday and zm 1.21.3. So, yes, it is related to it trying to pull in functions from ffmpeg.
How does one get around it?
rj
zoneminder
Site Admin
Post by zoneminder »
See various other threads for details. Essentially the ffmpeg project change their interfaces regularly and without notice. Existing versions of ZM don't work with the latest CVS ffmpeg, however the next version will.
Phil
cordel
Post by cordel »
You should be able to compile with ffmpeg 0.4.8 but not any new versions of ffmpeg till the next release. As ffmpeg is rapidly being developed and changes often in CVS it tends to break alot.
Regards,
Cordel
coutts99
Post by coutts99 »
Downgrading ffmpeg did solve the problem.
zoneminder
Site Admin
Ffmpeg 0.4.9-0-pre1 also works AFAIK with existing released versions of ZM.
Phil
