do you have a explanation of this :
https://www.youtube.com/watch?v=uaUuBCgiIbg
My zoneminder stream is flashing, i dont know why.
Thanks a lot
Seb.
My Zoneminder stream Flashing
Re: My Zoneminder stream Flashing
Don't feel bad, mine is doing the same thing. The stream is looking good in the montage review but not in the isolated screen stream. It was fine in v1.34.x BTW. I'm still looking into this.
- knight-of-ni
On my Rocky Linux 8 system, installing the php-process package solved that.
Thank you Knight. My build was missing the php-process and php-fpm. I installed those and viola - no more screen flashing.
Much thanks.
Much thanks.
Thanks a lot Knight
i installed the package and the problem is solve
