1.36.20 events not loading in live view
Since installing maint 20, I noticed underneath my live view, there is usually a list of events. Instead of a list I get 'Loading, please wait...'. It doesn't matter how long you wait, they never appear. If I go to the top of the screen and press console, that will bring me to a screen where i can see events and it tells me how many there are. Press on that number and then I see the list of events. This is the same list that should be showing under the live view. I searched around and could not find a solution. Anyone else have this problem or is it just me?
Re: 1.36.20 events not loading in live view
Yeah, I had it, and fixed it, but I had 3 issues and can't remember what fixed what... Have you run zmupdate.pl -f ?
Yes, I saw on someone elses post that zmupdate -f should be run, so I did try it but no joy. I also increased the Ajax time to 20000. No joy there either.
Ahh, I remember now.
https://github.com/ZoneMinder/zoneminder/issues/3526
The fix has already been committed so https://github.com/ZoneMinder/zoneminde ... ebd9cd9601 shows what to do, shout if you get stuck.
Thank you for the pointer. Now have the files fixed and works now!
This problem has been corrected in 1.36.21.
Thank you.
Thank you.
