Just received the v1.36.23 update alert and allowed it on Ubuntu 18.04.6 LTS system.
Install seemed normal with no errors, I also checked that zmupdate was okay.
Unfortunately all rtsp cameras are now failing, I occasionally get a frame but it is quickly replaced with a black screen with a message in the center "Unable to stream"
Even the very old camera doing JPEG via HTTP will only get one frame then a "not connected" message.
Nothing showing in logs but 'sudo service zoneminder status' now shows many of the following 3 lines:
17:23:34 root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl
17:23:34 pam_unix(sudo:session): session opened for user www-data by (uid=0)
17:23:34 pam_unix(sudo:session): session closed for user www-data
Release v1.36.23 kills streaming on Ubuntu
- AllenTuttle
Re: Release v1.36.23 kills streaming on Ubuntu
I too am having problems after upgrading from 1.36.20 to 1.36.23.
No issues with every version of 1.36 up to 1.36.20. Upgraded to 1.36.23 and now my cameras can't connect. I can post a log if that would help, but I suspect the .23 has issues that will be resolved soon (hopefully).
Thank you, yes, I am getting the same error as the post you linked.
Upgraded last night all streaming failing sporadically. Tons of errors in the log
Linux Mint 20.3
8/6/22, 10:39:32 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Garage Camera (9), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:32 AM CDT zmdc 3227 ERR 'zmc -m 3' exited abnormally, exit status 11 zmdc.pl -
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f33c6226133] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f33c8951609] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 4: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6de4) [0x7f33c6539de4] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 3: /usr/bin/zmc(+0xe3261) [0x5616e7a58261] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 2: /usr/bin/zmc(+0x727da) [0x5616e79e77da] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f33c895d420] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Backtrace 0: /usr/bin/zmc(+0xc4301) [0x5616e7a39301] zm_signal.cpp 101
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Signal address is 0x70, from 0x5616e79e77da zm_signal.cpp 80
8/6/22, 10:39:31 AM CDT zmc_m3 112483 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 50
8/6/22, 10:39:31 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Entry Camera (7), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:31 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Kitchen Camera (3), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:30 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Den Camera (2), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:29 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Front Camera (1), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:18 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Garage Camera (9), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:18 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Entry Camera (7), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:17 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Kitchen Camera (3), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:16 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Den Camera (2), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:15 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Front Camera (1), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:04 AM CDT zmdc 3227 ERR 'zmc -m 7' exited abnormally, exit status 11 zmdc.pl -
8/6/22, 10:39:04 AM CDT zmwatch 6507 ERR Shared data size conflict in shared_data for monitor Garage Camera (9), expected 768, got 760 zmwatch.pl -
8/6/22, 10:39:04 AM CDT zmc_m7 112293 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f4b9f6b0133] zm_signal.cpp 101
8/6/22, 10:39:04 AM CDT zmc_m7 112293 ERR Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f4ba1ddb609] zm_signal.cpp 101
Linux Mint 20.3
Upgraded to 1.36.24 and issue is resolved.
- AllenTuttle
Magic919 resolved issue with release of version 1.36.24.
