[Enhancement] UI Storage info report
emptyspiral
Post by emptyspiral »
This is my first post here, I'm a happy user of Zoneminder, so a big thank you to the developers for creating it! :)
I'm using the ZM repo debian packages, 1.36.x line.
I think it would be really useful if in the homepage of ZM the Storage data is not a dropdown only values.
I mean I can see at a simple glance the load, DB and shm usage, but I need to click on the Storage dropdown to see my single storage data usage.
It would be so much simpler (for me at least with a single storage defined) if instead of:
Storage v
the first storage usage would be shown, like:
Storage: Default: 43% v
I guess it would be a minor change, but a time saver and at-a-glance status review usability improvement.
Thank you.
justanotherguy
Re: [Enhancement] UI Storage info report
Post by justanotherguy »
Modify the following file
/usr/share/zoneminder/www/skins/classic/includes/functions.php
and the function getStorageHTML() as follows:
// Returns an html dropdown showing capacity of all storage areas
function getStorageHTML() {
  $result = '';
  if ( !canView('System') ) return $result;
  $func = function($S) {
    $class = '';
    if ( $S->disk_usage_percent() > 98 ) {
      $class = 'text-danger';
    } else if ( $S->disk_usage_percent() > 90 ) {
      $class = 'text-warning';
    $title = human_filesize($S->disk_used_space()) . ' of ' . human_filesize($S->disk_total_space()).
      ( ( $S->disk_used_space() != $S->event_disk_space() ) ? ' ' .human_filesize($S->event_disk_space()) . ' used by events' : '' );
//    return '<a class="dropdown-item '.$class.'" title="'.$title.'" href="?view=options&amp;tab=storage">'.validHtmlStr($S->Name()) . ': ' . $S->disk_usage_percent().'%' . '</a>';
      $res1 = '';
//       $res1 .= '<li id="getStorageHTML" class="nav-item dropdown mx-2' .$class. '">'.PHP_EOL;
         $res1 .= '<i class="material-icons md-18 mr-1">storage</i>'.PHP_EOL;
           $res1 .= translate('Storage'). ': ' .$S->disk_usage_percent().'%'.PHP_EOL;
//           $res1 .= '</li>'.PHP_EOL;
    return $res1;
  $storage_areas = ZM\Storage::find(array('Enabled'=>true));
  $num_storage_areas = count($storage_areas);
  $full_warning = 0;
  $full_error = 0;
  foreach ( $storage_areas as $area ) {
    if ( $area->disk_usage_percent() > 98 ) { $full_error++; continue; }
    if ( $area->disk_usage_percent() > 90 ) $full_warning++;
  $class = '';
  if ( $full_error ) {
  } else if ( $full_warning ) {
  $result .= '<li id="getStorageHTML" class="nav-item dropdown mx-2">'.PHP_EOL;
//  $result .= '<a class="dropdown-toggle mr-2 '.$class.'" href="#" id="dropdown_storage" data-toggle="dropdown" aria-haspopup="true" aria-expanded="false"><i class="material-icons md-18 mr-1">folder_shared</i>Storage</a>'.PHP_EOL;
//  $result .= '<div class="dropdown-menu" aria-labelledby="dropdown_storage">'.PHP_EOL;
    $result .= $func($area).PHP_EOL;
//  $result .= '</div>'.PHP_EOL;
  $result .= '</li>'.PHP_EOL;
  return $result;
That should give you what you are asking.
PS: Please backup the file before modifying, in case you need to restore it.
I have merged something like this queued for 1.36.25. Will be available in proposed ppa and master ppa as soon as packages finish building.
emptyspiral
I confirm the changes in 1.36.25 are exactly what I was hoping for.
Now with one storage only there is no more dropdown, just at a glance:
Default: 44%
Thank you!
Also thank you to @justanotherguy , did not get to make the change (deb package installed via repo, would need to remember to patch the file on every update and my neurons are kind of tired), but thank you for the option.
justanotherguy wrote: Sat Aug 27, 2022 1:25 pm
PS. Note to self: Now.. where was that donate button? :)
