Typo in auth.php in 1.36.24 via ppa:iconnor/zoneminder-1.36
hybrid
Post by hybrid »
Pretty sure I found a typo in auth.php line 51.
$user['Pasword'] = $bcrypt_hash;
Should be
$user['Password'] = $bcrypt_hash;
Edit: It was returning this error, just in case anyone else gets it
PHP Fatal error:  Uncaught TypeError: Cannot access offset of type string on string in /usr/share/zoneminder/www/includes/auth.php:51\nStack trace:\n#0 /usr/share/zoneminder/www/includes/actions/login.php(95): migrateHash()\n#1 /usr/share/zoneminder/www/index.php(240): require_once('...')\n#2 {main}\n  thrown in /usr/share/zoneminder/www/includes/auth.php on line 51
Re: Typo in auth.php in 1.36.24 via ppa:iconnor/zoneminder-1.36
It's worse than that. $user is actually a username string.... good find.
webdriver
Post by webdriver »
why my 1.36.24 doesn't report such error? I install via "sudo add-apt-repository ppa:iconnor/zoneminder-1.36"
That code only gets execute if we need to update hashed password. It would really only run on an upgrade from 1.32...
hybrid
Post by hybrid »
iconnor wrote: Mon Aug 29, 2022 7:55 pm It's worse than that. $user is actually a username string.... good find.
Yeah that's definitely what the error suggested, but just fixing the typo was enough to get me up and running.
I was in the process of adding in a type check and/or finding where $user was initially set when I noticed the typo.
I expect to release 1.36.25 tomorrow which will include the fixes.
