status check and start
jameswilson
Post by jameswilson »
i have had my home server change state to stopped. now im not sure if i did it and forgot etc, but can i cron a zm status start if stopped?
James
zoneminder
Site Admin
Post by zoneminder »
I'm not sure what you mean by a 'zm status start', can you explain a bit more?
Phil
jameswilson
ie check the status ir started or stoped
if stoped start it, so if for whatever reason its is currently stopped at say 5am it will start
James
rdmelin
Post by rdmelin »
This should do it, run from cron.
$!/bin/bash
zmpkg.pl status |grep stopped && zmpkg.pl start
jameswilson
thanks Ross
zoneminder
Site Admin
I think you can just do an unconditional start anyway, it shouldn't do any harm. Or of course a restart.
One day I'll learn the sequential shell command syntax!
Phil
