Reason for not disabling frames and analysis images?
krizzle
Post by krizzle »
I l'm running ZM 1.36.29 and recently disabled both analysis images and frames and realized it's saving me a ton of storage. What are the reasons why I would want to keep them turned on? What extra information do the frames or amaysis images net me?
Thanks.
Re: Reason for not disabling frames and analysis images?
There is no good reason if your cam supports video.
With that said I have an old Foscam that I'm using that works better saving jpeg's at the low frame rate (5 FPS) I have set.
Andyrh
Post by Andyrh »
I turn it on when I am resolving a detection problem. It helps to see what was detected. Other than that I leave it off.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
