no camera streaming on Zoneminder
Colibri
Post by Colibri »
Hi Everyone,
I'm using Zoneminder v 1.36.12 and Ubuntu 22.04 LTS on Odroid C4
I've bought a an Amcrest Cam IP2M-841B
I've look at the configuration on the wiki :
https://wiki.zoneminder.com/Amcrest
My Cam is now working but i can't see the display of this cam on the zoneminder console as you can see on the attachment.
I've already looking for a solution on this forum on this topic :
https://forums.zoneminder.com/viewtopic.php?p=119109
this one :
https://forums.zoneminder.com/viewtopic.php?t=15775
and this one :
https://forums.zoneminder.com/viewtopic.php?t=30024
but i didn't find a solution.
I've tried to change the PATH_ZMS and set /zm/cgi-bin/nph-zms as you can see in the attachment to.
I've tried many things to change the source, the mode, resolution.... but i can't fix it anyway.
I can see the streaming in rtsp and http with my navigator but i can't see it in zoneminder directly
Could you please help me because i don't know what can i do more, i spent lot of time to try a lot of differents things without succed.
Thank you for helping.
system Paths Configuration.png (78.17 KiB) Viewed 1910 times
console zoneminder.png (62 KiB) Viewed 1910 times
Andyrh
Re: no camera streaming on Zoneminder
Post by Andyrh »
h.264 or h.265?
My browser will not stream h.265.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
Colibri
Post by Colibri »
Thank you for answering andyrh, i have already tried with H.264 and H.265, same thin, no display, i will tried tomorrow with another browser, i'm using firefox, and i will try with chromium.
The problem is with your apache config.. The default apache config uses /usr/lib/cgi-bin but ZoneMinder's zms is in /usr/lib/zoneminder/cgi-bin.
ZoneMinder's default config for apache has a ScriptAlias line too, but they conflict.
Maybe try
sudo a2dissite 000-default
sudo systemctl reload apache2
Colibri
Post by Colibri »
iconnor wrote: Mon Oct 17, 2022 2:13 pm The problem is with your apache config.. The default apache config uses /usr/lib/cgi-bin but ZoneMinder's zms is in /usr/lib/zoneminder/cgi-bin.
Maybe try
Thank you Mr Connor, i will try.
Colibri
Post by Colibri »
Hell Everyone,
Sorry i was very busy, so I have just tried your solution Mr Connor but problem still the same, no display.
Do you have another solution?
Thank you have a nice day.
mr.graf
Post by mr.graf »
Hello!
Unfortunately, I do not know what operating system you have. For example on Slackware Linux I build Zoneminder from the source code. When building, I specify where the files should be located. In the file with VirtualHost:
 DocumentRoot /var/www/htdocs/zm
    ScriptAlias /cgi-bin /var/www/cgi-bin
    <Directory /var/www/cgi-bin>
In the zm.conf file
# Path to ZoneMinder cgi files
ZM_PATH_CGI=/var/www/cgi-bin
and in the Zoneminder interface (Options-Servers-Path to ZMS) be sure to write the correct path to nph-zms (this is actually a link to zms). In my case it is /cgi-bin/nph-zms i.e. where ScriptAlias points.
It may be enough on zms, I have not tried, I have it since the earliest versions. :)
