LOG page?
LOG page?
Used to show between options and groups. Not there anymore.
I can type it in and the log comes up.
Re: LOG page?
Is it turned off in Options->Logging?
Re: LOG page?
Uhm…
I don’t see an option to turn off the button.
Just options for what goes into it/them and where.
Options->Logging->? :(
Re: LOG page?
Yeah if you aren't putting anything into it, then it assumes there isn't anything there.
Re: LOG page?
OK, I see that now, thanks.
Is there a way to get it back to showing Info?
Only Warning or above survives a SAVE; reverts to None with Info in any LOG_LEVEL_ field.
Re: LOG page?
Uh.... I have mine set to warn... anything higher should work too in terms of making the word appear..
As to saving.... uh.... works for me, I'll take a look into it.
Re: LOG page?
Yes. Warn and above works.
Select info (for INF) won’t take.
Re: LOG page?
Ah, a bug. Found and fixed. Packages building. Info the level is being saved as Info, it just isn't auto-selecting in the dropdown.
Re: LOG page?
Yeah. I selected one before the upgrade and after it was seen and worked.
Thanks!
