Hi. First I want to congratulate the Zoneminder team and say thank you for a superb piece of software.
I just noted some weird behaviours in 1.36.32
First, the Edit, Delete and Select buttons of the console view are greyed and not working.
Also, the drop-down selections lack the x to delete selection. Here Capturing is selected:
Note that drop-downs don't close after selection.
It works on MontageReview:
And the search fields are not working:
ZM is v1.36.32, Ubuntu server 22.04, MySQL8, PHP 8. Browser is Firefox on Kubuntu 22.04, also tested on IE 11 and Edge on Windows.
Again, thank you very much for your patience and dedication.
Problems in 1.36.32 web UI
Re: Problems in 1.36.32 web UI
There is something breaking javascript. Please check javascript console. Might also have to view page source to find the issue.
Do you think it is something browser related?
Not likely. I’m on pretty much the same setup.
You might just try a reinstall-ZM only, not from scratch.
