Hey Guys,
I'm just wondering about this - on slow connections, such as DSL - streaming the images is possible without too much of a problem. When the stream window is closed, the zms process doesn't die, however it keeps on streaming the images. At some point, I believe it just times out. If one were to reopen the same window while the original stream hasn't timed out, zms starts streaming in a new http session. So you end up having two sessions streaming to one destination IP. Normally this isn't a problem, however on DSL connections this becomes quite SLOW. Is this a bug? Can this be fixed?
ZMS Timeout
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
