FC-37
chuck8530
FC-37
Post by chuck8530 »
I've upgraded my Fedora system to 37. The Repo 37 is there but not filled in. Can I use 36?
jogo
Re: FC-37
Post by jogo »
Zoneminder is now coming from rpmfusion, i.e. you may need to switch to the repos for 37. On the other hand you may not have to do anything, since the repo files do not explicitly mention 37, but only refer to the version by some variable.
chuck8530
Re: FC-37
Post by chuck8530 »
From what I can tell Repos doesn't have 37 and when I go to rpmfusion "this page doesn't exist ...
chuck8530
Re: FC-37
Post by chuck8530 »
So searching rpmfind.net I found zoneminder-1.36.32-1.fc37.src.rpm
dnf install - results in:
Error:
Problem: package zoneminder-1.36.32-1.fc37.src requires ffmpeg, but none of the providers can be installed
- package ffmpeg-5.1.2-3.fc37.x86_64 requires ffmpeg-libs(x86-64) = 5.1.2-3.fc37, but none of the providers can be installed
- package ffmpeg-5.1.2-9.fc37.x86_64 requires ffmpeg-libs(x86-64) = 5.1.2-9.fc37, but none of the providers can be installed
- package ffmpeg-libs-5.1.2-3.fc37.x86_64 conflicts with libavcodec-free provided by libavcodec-free-5.1.2-1.fc37.x86_64
- package ffmpeg-libs-5.1.2-9.fc37.x86_64 conflicts with libavcodec-free provided by libavcodec-free-5.1.2-1.fc37.x86_64
- problem with installed package libavcodec-free-5.1.2-1.fc37.x86_64
- conflicting requests
dnf install --allowerasing zoneminder-1.36.32-1.fc37.src.rpm
Last metadata expiration check: 1:51:49 ago on Fri 27 Jan 2023 05:46:14 PM MST.
Error: Will not install a source rpm package (zoneminder-1.36.32-1.fc37.src).
I need some help please
Re: FC-37
You should follow the instructions here:
https://zoneminder.readthedocs.io/en/st ... zoneminder
chuck8530
Re: FC-37
Post by chuck8530 »
System: 6.1.7-200.fc37.x86_64
OK, I went to the page you referenced - rpmfusion. I downloaded:
zoneminder-1.36.31-1.fc37.x86_64.rpm
zoneminder-common-1.36.31-1.fc37.x86_64.rpm
zoneminder-httpd-1.36.31-1.fc37.x86_64.rpm
ran: dnf install (the 3 above) and started zoneminder. Webbed to ZM and created cam-1:
Remote
Modect
192.168.0.51
8088
1280x1024
This is what I get:
[Starting Capture version 1.36.31]
[Can't connect to remote camera mid: 1 at 192.168.0.51: Permission denied]
[Unable to connect to the remote camera, aborting]
[Failed to prime capture of initial monitor]
I can browse to the camera, I can vlc the cam - ?Permission denied?
chuck8530
Re: FC-37
Post by chuck8530 »
selinux !*^%#&^%!$*&^!@#! selinux
Now working
