Hello everyone
Firstly I'm using multiple servers, so not your typical setup. But hopefully that's not a concern.
Having had my setup running for a number of years now, it's be working fantastic. I've decided to have a go at using the Sub stream of my cameras to perform the motion detection, hoping it'll help to reduce my CPU load across the servers.
Here's the basics of how I understand what's needed.
Main Stream - Nodect and linked to the Sub Stream
Sub Stream - Modect
The issue I have is that the Main Stream doesn't get triggered when the Sub Stream detects motion and starts to record. Is there something I've missed or have I miss understood someting?
Linked monitor function not working as expected
Re: Linked monitor function not working as expected
When linked monitors work, it's great. Unfortunately, they don't always work... dropped/missed events, etc.
What I've done to 'replace' linked monitors is:
Live view is, unfortunately, displayed at the low resolution. In Montage it's fine, since the images are smaller. The events display in high resolution.
Gerald
- use only RTSP cameras
save events in Camera Passsthrough mode
In camera Source, set resolution to 640x360
Gerald
