Following my first post:
viewtopic.php?t=32416
I migrated zoneminder to 1.36.33
I followed this tutorial:
viewtopic.php?t=30785
Now when I click on the "Download Video" button from the "Montage Review" menu, absolutely nothing happens.
The logs:
tail -f /var/log/zm/web_js.log
3/2/23, 3:42:29 PM GMT+1.308606 web_js[7588].ERR [127.0.0.1] [TypeError%3A%20%24j(...).modal%20is%20not%20a%20function] at zm/cache/skins_classic_views_js_montagereview-base-1677207184.js line 753
My setup:
I have a machine: GNU/Linux/Ubuntu Intel 20.04.5 LTS (Focal) with 8GB of RAM, with a system hard disk of 1TB for the OS and 4TB for the recorded video data.
And I installed on this server: ZoneMinder V1.34.26
I have so far installed 9 Dahua IP cameras on this system.
Thanks for your help
Upgrade 1.34 to 1.36 Video export problem (nothing happens)
Re: Upgrade 1.34 to 1.36 Video export problem (nothing happens)
I suspect you have more errors logged than that. I suspect a caching issue relating to the upgrade from 1.34.
clear out the contents of /var/cache/zoneminder/cache
sudo rm /var/cache/zoneminder/cache/*
And hold shift while doing a reload in the browser.
hi, thanks, i will try that.
Thank you very much Iconnor, the problem came from there.
