Bug: 1.37.37 - No sum in console view of column "month"
bebach8
Post by bebach8 »
Zoneminder 1.37.37
Ubuntu 20.04.06 LTS
In a console view there is no sum (number of events or events sizes) of column "Month". It is showing zero. Hour, day and week are working as expected. Please see attached image. Functionality not affected by this. Also Archived column is not shown and zones sum is moved to the left. Thank you for your hard work it is appreciated.
ZoneMinder 1.37 Bug.jpg (115.1 KiB) Viewed 2187 times
Re: Bug: 1.37.37 - No sum in console view of column "month"
I'm not seeing that on 1.37.37~20230407133847-
You seem to be missing the archive column, which may be why the zones are to the left.
bebach8
Post by bebach8 »
It is same in 20230410154831. Latest Chrome and latest Firefox show same error.
When it is clicked on "zero"
ZM Bug-02.jpg (31.16 KiB) Viewed 2127 times
this is URL that it goes to
http://xxx.xxx.xxx.xxx/zm/index.php?vie ... limit%5D=0
So, my opinion is that archived column is OK, moved to the left because sum of month column is actually missing.
everything is shifted over, your screenshot doesn't include the whole screen, The missing column is something on the left...
bebach8
Post by bebach8 »
Actually sir, you're absolutely right. Everything is shifted to the left. Checked in both latest Firefox and Chrome. Thank you for your hard work.
ZM Bug3.jpg (68.94 KiB) Viewed 2093 times
So what's missing?!
The Month column total events and storage should be >0
I see it too, now.
edit:
Crud. Yeah I was looking at the archived column, which is correctly 0.
bebach8
Post by bebach8 »
Nothing is missing, it is just offset to the left. Good eye. Minor nuisance.
There IS something missing, that's why they are shifted! I'd like to figure it out so I can fix it!
bebach8
Post by bebach8 »
Can't find what is missing. I don't know if it helps, but I started noticing this shift around same time as paging "problems" occurred.
No mater what is selected in drop-down or what number is in WEB_EVENTS_PER_PAGE it always reverts to 10 records per page (both Firefox and Chrome). Maybe someone else can spot what is missing in console view.
ZM Bug 4.jpg (131.55 KiB) Viewed 2027 times
ZM Bug 5.jpg (101.48 KiB) Viewed 2027 times
How 'bout the blank space for the empty "Storage" column?
bebach8
Post by bebach8 »
Fixed in 1.37.39. Thank you!
