16CH 120fps Live / 120fps "blues screens"
cordel
Post by cordel »
Okay so your going to need to find the correct card setting to insmod to get the card working.
If you see your card here http://www.bttv-gallery.de/
Lots of pictures- this may help track down the settings you need.
Hogface
Post by Hogface »
Ok, it looks like the Kodicom KMC-4400R
I says the the master is the second one detected. and the other 3 chips use 0x85.
sooo...in modprobe
would it look like?
options bttv card=77,133,133,133 radio=-1 tuner=4
________
Willys Jeep Truck
cordel
Post by cordel »
card=133,132,133,133
See this thread : http://www.zoneminder.com/forums/viewto ... t=kmc4400r
Hogface
Post by Hogface »
Excellent!
It's working
On Fedora 4 Core I didn't have to install the new bttv stuff.
With you help the 133,132,133,133 worked great.
Your awesome! Thanks for all the help!
________
Torneo
cordel
Post by cordel »
:wink:
Glad ya got it going.
Cheers,
Cordel
