Hello. I'm trying to tweak the settings of my zones to actually capture movement. Presnetly I am having to mocord until I do.
The problem I face is that after a make a change of settings in the zone, save, wait for movement and then go back to adjust, I can't see what the previous preset used was.
So let's say I chose "Fast, high sensitivity" , save and later go back, I can't see what I chose. The preset is back to "Chose Preset".
So I'll start taking notes and screenshots probably but I thought I asked. is there a way to tell, somewhere without having to resort to notes and screenshots?
Edit: I am on version 1.36.33
Viewing zone settings
Re: Viewing zone settings
I find it hard to disagree. I rely on them to begin with. It drives me to distraction that I can't get to set suitable settings to capture movement adequately. Not a failure of ZM but mine. I read and re-read the explanations on the docs and the good old examples. It seems the concepts are far too complex for me.
Problem is, I can't rely on movement. Front of house, street in front. Cars trigger. People don't unless in a group or multiple ones. I've lived with this for a long time. Now I've had events that really needed to have been captured and didn't. Cameras only function as deterrent.
I had to change to mocord but even after reducing resolution and fps, I can only keep around 5 days due to storage requirements.
I need to revisit this old problem. Thanks for your input.
Any practical and actionable advise on how to start that is not in the docs?
I forgot to add. It's a dome IP camera facing from a hight of about 2.5 mtr. So I have an angle, with a perspective. Same object (like a person) smaller on the road than closer to the door.
Maybe this helps to assist me. I forced an alarm when a person walked in front of the camera, on the pavement not on the road.
But if I then try to set the alarm to Alarmed Pixels, I can only set min and max values between 0 and 255. How are we to make the translation?
I'll go back again to docs in the meantime.
Event Id 4501
Frame Id 647
Zone 1-front-entrance
Pixel Diff 51
Alarm Px 17779 (2%)
Filter Px 0 (0%)
Blob Px 0 (0%)
Blobs 0
Blob Sizes 0 (0%)
Alarm Limits 0,0-0,0
Score 0
I only used this - https://wiki.zoneminder.com/Understandi ... or_Dummies
It worked pretty well for me but then I added ZMES as I couldn't really deal with some lighting changes and also steam plumes from a boiler next door.
I'd suggest having multiple zones worked better for me than one larger zone. Mine is a path that heads in the general direction of the camera.
I'll work with this again. I've never been able to crack it, I'll need to make the time.
Thank you.
Thank you.
I never was able to get consistent results with zones. ZMES works like 98% of the time which is good enough. You pretty much have to use ZMES if you want email alerts for person detection, unless you camera is in an area that won't see any sunlight or whatnot.
fastest way to test streams:
It is very hard place for the camera and motion detection I guess.
Road and drive (UK term, is where you park the car in front of the house). And shrubs on each side that sway in the wind. There is sunlight too.
But right now the challenge for me is understanding the way to use settings. I'll keep at it, thanks for the input.
