13.2 RELEASE using repo latest; pkg installed ZM 1.36.33; 5 monitors all showing video on the Montage screen; can Mocord on most cameras, one keeps giving me:
"Socket /var/run/zm/zms-805027s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to
http://zoneminder.readthedocs.io/en/lat ... window-etc for more information."
zms does manage to create some files in /var/run/zm:
-rw-r--r-- 1 www www 5B Jun 17 13:57 zm.pid
-rw-r--r-- 1 www www 5B Jun 17 13:58 zmaudit.pid
srwxr-xr-x 1 www www 0B Jun 17 13:57 zmdc.sock=
-rw------- 1 www www 0B Jun 17 13:50 zms-007176.lock
srwxr-xr-x 1 www www 0B Jun 17 13:50 zms-007176s.sock=
-rw------- 1 www www 0B Jun 17 13:51 zms-175936.lock
srwxr-xr-x 1 www www 0B Jun 17 13:51 zms-175936s.sock=
-rw------- 1 www www 0B Jun 17 14:06 zms-227290.lock
srwxr-xr-x 1 www www 0B Jun 17 14:06 zms-227290s.sock=
-rw------- 1 www www 0B Jun 17 13:57 zms-306778.lock
srwxr-xr-x 1 www www 0B Jun 17 13:57 zms-306778s.sock=
-rw------- 1 www www 0B Jun 17 13:54 zms-343496.lock
srwxr-xr-x 1 www www 0B Jun 17 13:54 zms-343496s.sock=
-rw------- 1 www www 0B Jun 17 13:56 zms-503670.lock
srwxr-xr-x 1 www www 0B Jun 17 13:56 zms-503670s.sock=
-rw------- 1 www www 0B Jun 17 13:49 zms-527772.lock
srwxr-xr-x 1 www www 0B Jun 17 13:52 zms-527772s.sock=
-rw------- 1 www www 0B Jun 17 13:54 zms-585329.lock
srwxr-xr-x 1 www www 0B Jun 17 13:56 zms-585329s.sock=
-rw------- 1 www www 0B Jun 17 13:50 zms-736816.lock
srwxr-xr-x 1 www www 0B Jun 17 13:50 zms-736816s.sock=
Additionally, zmninja shows only ? or ... on the monitor windows and if I try to use "Live View" I get this error in Nginx error.log:
[error] 922#100610: *4567 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-416142s.sock ) failed: Connection refused]" while reading response header from upstream, client: 172.18.0.154, server: , request: "GET /zm/index.php?view=request&request=stream&connkey=#########################&command=99 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php-fpm.sock:", host: "172.18.0.10", referrer: "
http://172.18.0.10/zm/index.php?view=watch&mid=5"
all directories are chmod www:www; I have hundreds of GB of disk space; 8GB of memory; the 5 cameras are streaming 640x480
# ZoneMinder url path to the zms streaming server
ZM_PATH_ZMS=/cgi-bin/nph-zms
# ZM_PATH_ZMS=/cgi-bin/zms
I've spent hours trying to crack the code with no luck.
