memory leak in mocord
fontiano
Re: memory leak in mocord
Post by fontiano »
burger wrote: Sun Jul 16, 2023 2:07 am Mocord/dect on a 2.5k pixel stream? I would only do modect or mocord on the low res stream. Try linked monitors or run two monitors (low / hi res stream w/only record on the hi res stream).
You could also try changing analysis fps to 2 or 3.
Ok, I will try this afternoon
On 1.34 I'm using same settings without issues.
Production: zm 1.34.26 - Debian 11 | Test: zm 1.36.33 - Debian 12
fontiano
Post by fontiano »
lowered frame analysis to 5 and slowly, after 1 hour, memory leak happened again
fontiano
I have identified the problem
Post by fontiano »
I need the recording to be divided into 30 second sections because I have to post-analyze the videos that have alarmed frames. With this setting the memory filling problem occurs.
With the default parameters instead it seems that the system is stable but it is not suitable for my needs.
As I wrote earlier with version 1.34.X it doesn't happen
1.34 used a fixed length array to hold images. If it ran out it would log lots of errors but not consume ram.
1.36+ uses a non-fixed length queue. It is limited by MaxImageBuffers. It includes the encoded 264 data as well as decoded images so can use more ram than in 1.34. Again though, if you hit MaxImageBuffers packets in the queue, it will be logging all kinds of warnings and errors.
If you are running out of ram, ZM will be complaining about it bitterly. Go look in your logs.
fontiano
Post by fontiano »
iconnor wrote: Fri Jul 28, 2023 2:17 pm 1.34 used a fixed length array to hold images. If it ran out it would log lots of errors but not consume ram.
these are my logging settings
with these parameters in the logs I only see the following warnings (which I also see in modect mode but without having memory problems)
"Found locked packet when trying to free up video packets. This basically means that decoding is not keeping up."
"You have set the max video packets in the queue to 45. The queue is full. Either Analysis is not keeping up or your camera's keyframe interval 16 is larger than this setting."
Is there anyone who can try to reproduce the anomaly by setting the parameters like me?
"General" section
Function: Mocord
Analysis Enabled: true
"Misc" section
Section length 30
Minimum section lenght 15
revplant
Post by revplant »
I didnt have any footage I cared to save so I went ahead and deleted and recreated the monitors, kind of inconvenient but now everything appears to be normal again, knock on wood, and has been for a little bit, i'm barely at 1.5 GB of RAM usage now. Hubspot partner agency
stock market courses
jrtaylor71
Post by jrtaylor71 »
There is a memory leak in 1.36 and 1.37. It happens when zmc restarts on a failed rtsp connection. It looks like it releases some of the memory not all of it and each time it restarts its releases less memory. 1.36 takes longer than 1.37. I have 2 different systems that do the same thing.
CPU usage climbs as the memory is used up until it uses up the swap file and the server becomes unresponsive.
Here is the kernel dump info from zmc. This is on a clean install that was done last night on Ubuntu 22 with 1.36.33. The VM is configured with 8 CPU's and 16GB of memory. The only thing I took from the old system was the config.
Aug  2 08:54:10 zoneminder kernel: [43799.510494] zmc invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
Aug  2 08:54:10 zoneminder kernel: [43799.510530] CPU: 5 PID: 1329 Comm: zmc Not tainted 5.15.0-78-generic #85-Ubuntu
Aug  2 08:54:10 zoneminder kernel: [43799.510534] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 09/30/2014
Aug  2 08:54:10 zoneminder kernel: [43799.510542] Call Trace:
Aug  2 08:54:10 zoneminder kernel: [43799.510550]  <TASK>
Aug  2 08:54:10 zoneminder kernel: [43799.510568]  show_stack+0x52/0x5c
Aug  2 08:54:10 zoneminder kernel: [43799.510610]  dump_stack_lvl+0x4a/0x63
Aug  2 08:54:10 zoneminder kernel: [43799.510635]  dump_stack+0x10/0x16
Aug  2 08:54:10 zoneminder kernel: [43799.510637]  dump_header+0x53/0x228
Aug  2 08:54:10 zoneminder kernel: [43799.510649]  oom_kill_process.cold+0xb/0x10
Aug  2 08:54:10 zoneminder kernel: [43799.510652]  out_of_memory+0x106/0x2e0
Aug  2 08:54:10 zoneminder kernel: [43799.510678]  __alloc_pages_slowpath.constprop.0+0x9b7/0xa80
Aug  2 08:54:10 zoneminder kernel: [43799.510694]  __alloc_pages+0x311/0x330
Aug  2 08:54:10 zoneminder kernel: [43799.510697]  alloc_pages+0x9e/0x1e0
Aug  2 08:54:10 zoneminder kernel: [43799.510704]  __page_cache_alloc+0x7e/0x90
Aug  2 08:54:10 zoneminder kernel: [43799.510707]  pagecache_get_page+0x152/0x590
Aug  2 08:54:10 zoneminder kernel: [43799.510709]  ? page_cache_ra_unbounded+0x166/0x210
Aug  2 08:54:10 zoneminder kernel: [43799.510717]  filemap_fault+0x488/0xab0
Aug  2 08:54:10 zoneminder kernel: [43799.510719]  ? filemap_map_pages+0x309/0x400
Aug  2 08:54:10 zoneminder kernel: [43799.510722]  __do_fault+0x3c/0x120
Aug  2 08:54:10 zoneminder kernel: [43799.510733]  do_read_fault+0xeb/0x160
Aug  2 08:54:10 zoneminder kernel: [43799.510736]  do_fault+0xa0/0x2e0
Aug  2 08:54:10 zoneminder kernel: [43799.510738]  handle_pte_fault+0x1cd/0x240
Aug  2 08:54:10 zoneminder kernel: [43799.510741]  __handle_mm_fault+0x405/0x6f0
Aug  2 08:54:10 zoneminder kernel: [43799.510744]  handle_mm_fault+0xd8/0x2c0
Aug  2 08:54:10 zoneminder kernel: [43799.510747]  do_user_addr_fault+0x1c9/0x670
Aug  2 08:54:10 zoneminder kernel: [43799.510765]  exc_page_fault+0x77/0x170
Aug  2 08:54:10 zoneminder kernel: [43799.510779]  asm_exc_page_fault+0x27/0x30
Aug  2 08:54:10 zoneminder kernel: [43799.510786] RIP: 0033:0x7fec9c1bd549
Aug  2 08:54:10 zoneminder kernel: [43799.510838] Code: Unable to access opcode bytes at RIP 0x7fec9c1bd51f.
Aug  2 08:54:10 zoneminder kernel: [43799.510840] RSP: 002b:00007fffcbcb85f0 EFLAGS: 00010206
Aug  2 08:54:10 zoneminder kernel: [43799.510843] RAX: 0000000a329a783b RBX: 000056390823a200 RCX: 0000000000000000
Aug  2 08:54:10 zoneminder kernel: [43799.510845] RDX: 0000000000000000 RSI: 0000000a32907180 RDI: 0000000000000001
Aug  2 08:54:10 zoneminder kernel: [43799.510847] RBP: 00007fffcbcb8600 R08: 0000000000000000 R09: 0000000000000000
Aug  2 08:54:10 zoneminder kernel: [43799.510848] R10: 00007fffcbd6c080 R11: 00007fffcbd6c090 R12: 0000000000000000
Aug  2 08:54:10 zoneminder kernel: [43799.510849] R13: 00005639081e2840 R14: 0000000000000000 R15: 00007fec9c24c5de
Aug  2 08:54:10 zoneminder kernel: [43799.510852]  </TASK>
Aug  2 08:54:10 zoneminder kernel: [43799.510857] Mem-Info:
Aug  2 08:54:10 zoneminder kernel: [43799.510864] active_anon:1669367 inactive_anon:2238551 isolated_anon:0
Aug  2 08:54:10 zoneminder kernel: [43799.510864]  active_file:124 inactive_file:379 isolated_file:0
Aug  2 08:54:10 zoneminder kernel: [43799.510864]  unevictable:65969 dirty:0 writeback:0
Aug  2 08:54:10 zoneminder kernel: [43799.510864]  slab_reclaimable:26330 slab_unreclaimable:20488
Aug  2 08:54:10 zoneminder kernel: [43799.510864]  mapped:61343 shmem:61051 pagetables:12876 bounce:0
Aug  2 08:54:10 zoneminder kernel: [43799.510864]  kernel_misc_reclaimable:0
Aug  2 08:54:10 zoneminder kernel: [43799.510864]  free:33654 free_pcp:508 free_cma:0
Aug  2 08:54:10 zoneminder kernel: [43799.510871] Node 0 active_anon:6677468kB inactive_anon:8954204kB active_file:496kB inactive_file:1516kB unevictable:263876kB isolated(anon):0kB isolated(file):0kB mapped:245372kB dirty:0kB writeback:0kB shmem:244204kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 81920kB writeback_tmp:0kB kernel_stack:6800kB pagetables:51504kB all_unreclaimable? yes
Aug  2 08:54:10 zoneminder kernel: [43799.510876] Node 0 DMA free:13312kB min:60kB low:72kB high:84kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15360kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Aug  2 08:54:10 zoneminder kernel: [43799.510882] lowmem_reserve[]: 0 2886 15859 15859 15859
Aug  2 08:54:10 zoneminder kernel: [43799.510887] Node 0 DMA32 free:64232kB min:12288kB low:15360kB high:18432kB reserved_highatomic:0KB active_anon:1365508kB inactive_anon:1605768kB active_file:8kB inactive_file:4kB unevictable:0kB writepending:0kB present:3129280kB managed:3063744kB mlocked:0kB bounce:0kB free_pcp:1836kB local_pcp:496kB free_cma:0kB
Aug  2 08:54:10 zoneminder kernel: [43799.510892] lowmem_reserve[]: 0 0 12973 12973 12973
Aug  2 08:54:10 zoneminder kernel: [43799.510897] Node 0 Normal free:57072kB min:57276kB low:71080kB high:84884kB reserved_highatomic:2048KB active_anon:5311960kB inactive_anon:7348436kB active_file:1464kB inactive_file:1012kB unevictable:263876kB writepending:0kB present:13631488kB managed:13293204kB mlocked:263876kB bounce:0kB free_pcp:196kB local_pcp:0kB free_cma:0kB
Aug  2 08:54:10 zoneminder kernel: [43799.510902] lowmem_reserve[]: 0 0 0 0 0
Aug  2 08:54:10 zoneminder kernel: [43799.510906] Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 1*1024kB (U) 2*2048kB (UM) 2*4096kB (M) = 13312kB
Aug  2 08:54:10 zoneminder kernel: [43799.510920] Node 0 DMA32: 723*4kB (UE) 757*8kB (UE) 517*16kB (UE) 318*32kB (UE) 204*64kB (UE) 68*128kB (UME) 20*256kB (UE) 4*512kB (ME) 6*1024kB (ME) 0*2048kB 0*4096kB = 62468kB
Aug  2 08:54:10 zoneminder kernel: [43799.510936] Node 0 Normal: 2162*4kB (UMEH) 1201*8kB (UMEH) 870*16kB (UMEH) 557*32kB (UME) 97*64kB (UMEH) 5*128kB (UMH) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 56848kB
Aug  2 08:54:10 zoneminder kernel: [43799.510953] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Aug  2 08:54:10 zoneminder kernel: [43799.510955] 77956 total pagecache pages
Aug  2 08:54:10 zoneminder kernel: [43799.510960] 14012 pages in swap cache
Aug  2 08:54:10 zoneminder kernel: [43799.510964] Swap cache stats: add 2265765, delete 2251721, find 10994355/11078106
Aug  2 08:54:10 zoneminder kernel: [43799.510966] Free swap  = 0kB
Aug  2 08:54:10 zoneminder kernel: [43799.510972] Total swap = 4194300kB
Aug  2 08:54:10 zoneminder kernel: [43799.510973] 4194190 pages RAM
Aug  2 08:54:10 zoneminder kernel: [43799.510974] 0 pages HighMem/MovableOnly
Aug  2 08:54:10 zoneminder kernel: [43799.510975] 101113 pages reserved
Aug  2 08:54:10 zoneminder kernel: [43799.510976] 0 pages hwpoisoned
Aug  2 08:54:10 zoneminder kernel: [43799.510976] Tasks state (memory values in pages):
Aug  2 08:54:10 zoneminder kernel: [43799.510977] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Aug  2 08:54:10 zoneminder kernel: [43799.510981] [    446]     0   446    82425      608   684032      302          -250 systemd-journal
Aug  2 08:54:10 zoneminder kernel: [43799.510985] [    493]     0   493    88721     6775   122880        0         -1000 multipathd
Aug  2 08:54:10 zoneminder kernel: [43799.510988] [    496]     0   496     6664      512    81920      659         -1000 systemd-udevd
Aug  2 08:54:10 zoneminder kernel: [43799.510991] [    710]   104   710    22338      462    73728      222             0 systemd-timesyn
Aug  2 08:54:10 zoneminder kernel: [43799.510994] [    714]     0   714    12783      577    86016      494             0 VGAuthService
Aug  2 08:54:10 zoneminder kernel: [43799.510997] [    715]     0   715    78753      685   110592      303             0 vmtoolsd
Aug  2 08:54:10 zoneminder kernel: [43799.510999] [    814]   101   814     4029      711    69632      182             0 systemd-network
Aug  2 08:54:10 zoneminder kernel: [43799.511002] [    816]   102   816     6382      367    94208     1000             0 systemd-resolve
Aug  2 08:54:10 zoneminder kernel: [43799.511004] [    850]     0   850     1723      529    49152       48             0 cron
Aug  2 08:54:10 zoneminder kernel: [43799.511007] [    851]   103   851     2195      635    53248      209          -900 dbus-daemon
Aug  2 08:54:10 zoneminder kernel: [43799.511009] [    857]     0   857    20709      702    61440       65             0 irqbalance
Aug  2 08:54:10 zoneminder kernel: [43799.511017] [    860]     0   860     8168      834   106496     2061             0 networkd-dispat
Aug  2 08:54:10 zoneminder kernel: [43799.511021] [    862]     0   862    58624      285    86016      149             0 polkitd
Aug  2 08:54:10 zoneminder kernel: [43799.511024] [    866]   107   866    55600     1051    86016      186             0 rsyslogd
Aug  2 08:54:10 zoneminder kernel: [43799.511026] [    873]     0   873     3755      667    65536      157             0 systemd-logind
Aug  2 08:54:10 zoneminder kernel: [43799.511029] [    875]     0   875    98143      735   122880      261             0 udisksd
Aug  2 08:54:10 zoneminder kernel: [43799.511032] [    912]     0   912     1543      203    49152        6             0 agetty
Aug  2 08:54:10 zoneminder kernel: [43799.511034] [    935]     0   935     3856      493    65536      375         -1000 sshd
Aug  2 08:54:10 zoneminder kernel: [43799.511037] [    942]     0   942    27434      906   110592     1938             0 unattended-upgr
Aug  2 08:54:10 zoneminder kernel: [43799.511039] [    954]     0   954    79489      746   118784      380             0 ModemManager
Aug  2 08:54:10 zoneminder kernel: [43799.511042] [   1006]   114  1006  1311322    12201   991232    54216             0 mariadbd
Aug  2 08:54:10 zoneminder kernel: [43799.511045] [   1026]     0  1026    61725      986   167936     1156             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511048] [   1206]    33  1206     9762     1033   110592     2350             0 zmdc.pl
Aug  2 08:54:10 zoneminder kernel: [43799.511050] [   1269]    33  1269   671442   517346  4919296    26746             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511053] [   1291]    33  1291   867812   676961  6201344    47805             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511056] [   1300]    33  1300  1785439  1191778 13762560   453550             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511058] [   1313]    33  1313   166791    27139   925696    36238             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511061] [   1329]    33  1329   257806   142527  1564672    10797             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511063] [   1449]    33  1449   289326   153184  1822720    21341             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511066] [   1492]    33  1492    14831      747   163840     8139             0 /usr/bin/zmcont
Aug  2 08:54:10 zoneminder kernel: [43799.511069] [   1531]    33  1531   235912    60903  1134592     6016             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511072] [   1608]    33  1608    13389     1635   143360     5825             0 zmfilter.pl
Aug  2 08:54:10 zoneminder kernel: [43799.511075] [   1664]    33  1664    14580     2373   151552     6185             0 zmfilter.pl
Aug  2 08:54:10 zoneminder kernel: [43799.511077] [   1672]    33  1672    16202     4811   172032     5309             0 zmaudit.pl
Aug  2 08:54:10 zoneminder kernel: [43799.511080] [   1705]    33  1705     9627     1247   114688     2498             0 zmwatch.pl
Aug  2 08:54:10 zoneminder kernel: [43799.511082] [   1735]    33  1735     9558      595   114688     2854             0 zmstats.pl
Aug  2 08:54:10 zoneminder kernel: [43799.511085] [  13560]    33 13560  1030438   787912  7143424    44784             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511088] [  13636]    33 13636   753024   339165  5419008   290108             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511091] [ 202410]     0 202410   385182     2422   339968     2040          -900 snapd
Aug  2 08:54:10 zoneminder kernel: [43799.511098] [ 395829]     0 395829   107671     5424   278528     6621             0 fwupd
Aug  2 08:54:10 zoneminder kernel: [43799.511101] [ 395908]     0 395908    59902      808   102400      107             0 upowerd
Aug  2 08:54:10 zoneminder kernel: [43799.511109] [ 396003]     0 396003    20346      529    57344       81             0 gpg-agent
Aug  2 08:54:10 zoneminder kernel: [43799.511112] [ 459049]    33 459049    61775     1272   196608     1422             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511115] [ 460976]    33 460976    62112     1257   200704     1515             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511117] [ 461401]    33 461401    62101     1752   196608     1169             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511120] [ 461592]    33 461592    62107     1072   200704     1707             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511122] [ 462408]    33 462408    62122     1242   196608     1580             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511125] [ 462581]    33 462581    48934     1313   176128     1181             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511128] [ 462582]    33 462582    62079     1059   196608     1577             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511130] [ 462653]    33 462653    62073     1628   196608     1065             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511133] [ 462770]    33 462770    62079     1560   196608     1094             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511135] [ 462771]    33 462771    62079     1624   196608     1102             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511138] [ 462854]    33 462854    62079     1530   196608     1145             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511140] [ 462919]    33 462919    62073     1502   196608     1107             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511143] [ 462929]    33 462929    15415     1091   118784      565             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511146] [ 462937]    33 462937    61889      907   139264     1120             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511148] [ 462939]    33 462939    15415     1069   118784      569             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511154] [ 462975]    33 462975    61811     1028   155648     1077             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511157] [ 462976]    33 462976    61889      796   139264     1130             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511159] [ 462977]    33 462977    60735     1632   188416     1014             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511163] [ 462979]    33 462979    15415     1159   118784      564             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511165] [ 462980]    33 462980    15415     1235   118784      564             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511168] [ 462982]    33 462982    61889      783   139264     1132             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511171] [ 462984]    33 462984    15415     1188   118784      569             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511173] [ 462985]    33 462985    15415      955   118784      566             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511176] [ 462986]    33 462986    15415     1102   118784      574             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511179] [ 463018]    33 463018    61891      807   139264     1123             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511181] [ 463023]    33 463023    62073     1329   196608     1067             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511184] [ 463060]    33 463060    61891      785   139264     1124             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511187] [ 463064]    33 463064    61891      763   139264     1125             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511193] [ 463065]    33 463065    15415     1019   118784      562             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511196] [ 463112]    33 463112    61811     1033   155648     1069             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511199] [ 463120]    33 463120    61873      745   139264     1119             0 apache2
Aug  2 08:54:10 zoneminder kernel: [43799.511202] [ 463147]    33 463147    56917    13896   339968        0             0 zmc
Aug  2 08:54:10 zoneminder kernel: [43799.511204] [ 463200]     0 463200     4058     1115    73728        0             0 sshd
Aug  2 08:54:10 zoneminder kernel: [43799.511207] [ 463203]   106 463203     3856      508    73728        2             0 sshd
Aug  2 08:54:10 zoneminder kernel: [43799.511209] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=zoneminder.service,mems_allowed=0,global_oom,task_memcg=/system.slice/zoneminder.service,task=zmc,pid=1300,uid=33
Aug  2 08:54:10 zoneminder kernel: [43799.511256] Out of memory: Killed process 1300 (zmc) total-vm:7141756kB, anon-rss:4741096kB, file-rss:1708kB, shmem-rss:24308kB, UID:33 pgtables:13440kB oom_score_adj:0
This is the config for the camera that was offline. It is currently set to none but was set to modcord.
*************************** 6. row ***************************
               Notes:
            ServerId: 0
           StorageId: 2
                Type: Ffmpeg
            Function: None
             Enabled: 1
     DecodingEnabled: 1
      LinkedMonitors: NULL
            Triggers:
           ONVIF_URL:
      ONVIF_Username:
      ONVIF_Password:
       ONVIF_Options:
              Device:
             Channel: 0
              Format: 0
      V4LMultiBuffer: NULL
 V4LCapturesPerFrame: 1
            Protocol: NULL
              Method: rtpRtsp
                Host: NULL
                Port:
             SubPath:
                Path: rtsp://192.168.173.61:554/11
          SecondPath: NULL
             Options: NULL
                User: NULL
                Pass: NULL
               Width: 2560
              Height: 1440
             Colours: 4
             Palette: 0
         Orientation: ROTATE_0
       Deinterlacing: 0
  DecoderHWAccelName: NULL
DecoderHWAccelDevice: NULL
           SaveJPEGs: 0
         VideoWriter: 2
         OutputCodec: 27
             Encoder: libx264
     OutputContainer: NULL
   EncoderParameters: crf=1
         RecordAudio: 0
        RTSPDescribe: 0
          Brightness: -1
            Contrast: -1
                 Hue: -1
              Colour: -1
         EventPrefix: Event-
         LabelFormat: %N - %d/%m/%y %H:%M:%S
              LabelX: 0
              LabelY: 0
           LabelSize: 1
    ImageBufferCount: 3
 MaxImageBufferCount: 0
         WarmupCount: 0
       PreEventCount: 5
      PostEventCount: 5
  StreamReplayBuffer: 0
     AlarmFrameCount: 1
       SectionLength: 300
    MinSectionLength: 10
           FrameSkip: 0
     MotionFrameSkip: 0
    AnalysisFPSLimit: 2.00
 AnalysisUpdateDelay: 0
              MaxFPS: NULL
         AlarmMaxFPS: NULL
   FPSReportInterval: 100
        RefBlendPerc: 6
   AlarmRefBlendPerc: 6
        Controllable: 0
           ControlId: NULL
       ControlDevice: NULL
      ControlAddress: NULL
     AutoStopTimeout: NULL
         TrackMotion: 0
          TrackDelay: NULL
      ReturnLocation: -1
         ReturnDelay: NULL
     ModectDuringPTZ: 0
         DefaultRate: 100
        DefaultScale: 100
        DefaultCodec: auto
   SignalCheckPoints: 0
   SignalCheckColour: #0000BE
           WebColour: #e4fd16
                Exif: 0
            Sequence: 6
           ZoneCount: 1
             Refresh: NULL
            Latitude: NULL
           Longitude: NULL
          RTSPServer: 0
      RTSPStreamName:
          Importance: Normal
That's totally possible, and should be easy to recreate.
I have several very flakey cameras though, and I don't see that here... but then I give my machine a lot of ram.
jrtaylor71
Here is what htop is showing. Monitor 10 is a camera that is on wifi that bounces on and off. It has lots of sub processes while all the rest only have 5 total.
a monitor should only have about 5 threads. Maybe a couple more ffmpeg is using a threaded decoder.
A possibility is that it is taking too long to close events. We use a separate thread for each event to do the writing. Closing an event should kill off the thread.
fontiano
maybe I fixed it
Post by fontiano »
I think my problem was not related to bad network or bad rstp stream.
On my test environment I had only 1 SSD disk (SO, database, video storage etc.) and I thought it was enough for 2 cameras
The behavior changed after I added a dedicated disk (mechanical) for video storage.
Now the memory consumption has remained stable after 1 hour. I've added more cameras, let's see what happens in the next few hours.
For now, thank you all.
fontiano
fixed
Post by fontiano »
The hard drive dedicated to video storage solved the problem although I don't understand why
