All videos are saved with the correct local time (UTC+2.00), also the inserted time in the snapshot pictures show the correct local time, but in the events list start/end-time show UTC time.
Where/how do I set that the local times are displayed?
ZM-options TIMEZONE is set to "(GMT+02:00) Europe, Madrid"; MySQL timezone is set the same
as said, ZM obviously knows the local time as it inserts the correct local time into snapshot images
I think it must be a display setting have I missed
Can you hint me in the right direction?
Thanks!
How to show local time (instead of UTC) in events-list?
- danielmalaga
- Contact:
Re: How to show local time (instead of UTC) in events-list?
Best way to fix this is to add the timezone to php.ini
This example is for Debian 12
[Date]
Ctrl+o Enter to save
CTRL+x to exit
Restart Apache
service apache2 restart
[Date]
CTRL+x to exit
Restart Apache
- danielmalaga
- Contact:
SOLVED.
Thank you very much, bbunge!
Changing date.timezone in php.ini did the trick. Times are now displayed in my local time.
Curious -
Did you not get a prompt at (initial) setup time to set Options->System->TIMEZONE?
- danielmalaga
- Contact:
I am not sure if there was a prompt or if I set it up according to my old setup on my last install on another machine.
Anyway, Options->System->TIMEZONE is/was set correct, and this was not the problem. The problem was that in php.ini date.timezone was set to 'UTC' instead of 'Europe/Madrid' (in my case)
Interesting.
Thanks.
Thanks.
