Currently, one camera is delayed slightly more than the other and the error is occurring on the second camera almost all of the time. I was also able to recreate this behavior by also running two manual requests concurrently and an example of the failure "Failed to load delegate from libedgetpu.so.1" is shown below. This error does not occur at all in multiple frames for the first instance request and occurs multiple times in the second requested instance. Running a single isolated request is successful and does not create the issue.
I currently have tpu_max_processes=1 in objectconfig.ini and I have also tried 2, but the error occurs either way. If there's a setting I'm missing that can correct this or any additional information that would be helpful, please let me know.
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG1 detect_sequence.py:654 [perf: Starting for frame:81]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG1 detect_sequence.py:664 [Sequence of detection types to execute: ['object', 'face']]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG1 detect_sequence.py:669 [============ Frame: 81 Running object detection type in sequence ==================]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG3 detect_sequence.py:689 [object has a same_model_sequence strategy of first]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG1 detect_sequence.py:701 [--------- Frame:81 Running variation: #1 -------------]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG2 coral_edgetpu.py:51 [Waiting for pyzm_uid33_tpu_lock portalock...]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG2 coral_edgetpu.py:53 [Got pyzm_uid33_tpu_lock portalock]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG1 coral_edgetpu.py:89 [|--------- Loading "TPU object detection" model from disk -------------|]
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG2 coral_edgetpu.py:68 [Released portalock pyzm_uid33_tpu_lock]
07/25/23 06:15:38 zmesdetect_m2[1961308] ERR detect_sequence.py:713 [Error running model: Failed to load delegate from libedgetpu.so.1
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG2 detect_sequence.py:714 [Traceback (most recent call last):
File "/usr/lib/python3.10/site-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
delegate = Delegate(library, options)
File "/usr/lib/python3.10/site-packages/tflite_runtime/interpreter.py", line 119, in __init__
raise ValueError(capture.message)
ValueError
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.10/site-packages/pyzm/ml/detect_sequence.py", line 710, in detect_stream
_b,_l,_c,_m = m.detect(image=frame)
File "/usr/lib/python3.10/site-packages/pyzm/ml/object.py", line 71, in detect
b,l,c,_model_names = self.model.detect(image)
File "/usr/lib/python3.10/site-packages/pyzm/ml/coral_edgetpu.py", line 161, in detect
self.load_model()
File "/usr/lib/python3.10/site-packages/pyzm/ml/coral_edgetpu.py", line 94, in load_model
self.model = make_interpreter(self.options.get('object_weights'))
File "/usr/lib/python3.10/site-packages/pycoral/utils/edgetpu.py", line 87, in make_interpreter
delegates = [load_edgetpu_delegate({'device': device} if device else {})]
File "/usr/lib/python3.10/site-packages/pycoral/utils/edgetpu.py", line 52, in load_edgetpu_delegate
return tflite.load_delegate(_EDGETPU_SHARED_LIB, options or {})
File "/usr/lib/python3.10/site-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
raise ValueError('Failed to load delegate from {}\n{}'.format(
ValueError: Failed to load delegate from libedgetpu.so.1
07/25/23 06:15:38 zmesdetect_m2[1961308] DBG1 detect_sequence.py:701 [--------- Frame:81 Running variation: #2 -------------]
