Can't run query INSERT INTO `Logs` - Running in read-only mode
torkilt
Post by torkilt »
Hi
Suddenlyy started seeing these and zoneminder doesn't work.
Aug 05 19:02:44 zm zmc_m5[2520]: ERR [zmc_m5] [Can't run query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1691254964.920227, 'zmc_m5', 0, 2597, 0, 'INF', 'Driveway: 000 - Opened new event 0, section start', 'zm_monitor.cpp', 1933 ): Running in read-only mode]
RHEL 9.2 with zoneminder-1.36.33-3.el9.x86_64.
MariaDB is running and is _not_ readonly:
MariaDB [(none)]> SELECT @@global.read_only;
| @@global.read_only |
|                  0 |
1 row in set (0.000 sec)
Suggestions? I haven't found anything else in the logs to go by. File systems are also working.
Mvh.
Torkil
torkilt
Re: Can't run query INSERT INTO `Logs` - Running in read-only mode
Post by torkilt »
Aug 07 08:13:01 zm zmpkg.pl[21346]: DBD::mysql::st execute failed: Running in read-only mode at /usr/share/perl5/vendor_perl/ZoneMinder/Logger.pm line 627.
torkilt
Post by torkilt »
I added the following[1] while mucking around and that may have fixed it:
innodb_buffer_pool_size = 2G
innodb_buffer_pool_instances = 2
innodb_log_buffer_size = 32M
innodb_log_file_size = 512M
innodb_open_files = 5000
table_open_cache = 1000
net_read_timeout = 60
net_write_timeout = 120
connect_timeout = 20
max_connections = 5000
[1] viewtopic.php?p=104746#p104746
I expect a DB restart would have cleared it. Hopefully your changes will prevent it happening again.
torkilt
Post by torkilt »
Magic919 wrote: Mon Aug 07, 2023 8:41 am I expect a DB restart would have cleared it. Hopefully your changes will prevent it happening again.
I expected so as well but it did not. Fingers crossed.
Did MariaDB log anything during this?
torkilt
Post by torkilt »
Stopped working again *grrr*
Mariadb is only showing this:
Aug 27 10:43:51 zm mariadb-check-socket[3993]: Socket file /var/lib/mysql/mysql.sock exists.
Aug 27 10:43:51 zm mariadb-check-socket[3993]: No process is using /var/lib/mysql/mysql.sock, which means it is a garbage, so it will be removed automatically.
Aug 27 10:43:52 zm mariadb-prepare-db-dir[4019]: Database MariaDB is probably initialized in /var/lib/mysql already, nothing is done.
Aug 27 10:43:52 zm mariadb-prepare-db-dir[4019]: If this is not the case, make sure the /var/lib/mysql is empty before running mariadb-prepare-db-dir.
Aug 27 10:43:52 zm mariadbd[4054]: 2023-08-27 10:43:52 0 [Note] /usr/libexec/mariadbd (mysqld 10.5.16-MariaDB) starting as process 4054 ...
Aug 27 10:43:52 zm systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Restarting zm, restarting mariadb and rebooting the box makes no difference.
torkilt
Post by torkilt »
From /var/log/mariadb/mariadb.log:
2023-08-27 10:43:52 0 [ERROR] mariadbd: Can't create/write to file '/run/mariadb/mariadb.pid' (Errcode: 2 "No such file or directory")
2023-08-27 10:43:52 0 [ERROR] Can't start server: can't create PID file: No such file or directory
Found this rather ancient bug with a solution:
https://bugzilla.redhat.com/show_bug.cgi?id=1373006
