event play button greyed out, always defaults to stop
neuronetv
Post by neuronetv »
I'm running zoneminder v1.34.23 on a raspberry pi4. got two problems:
1) any event playback always defaults to stop (at the very bottom) and the play button is greyed out (see screenshot attached) and replay always defaults to 'none' if I change it to 'single' and then select 1x it plays. is there a way to make replay default to 'single'?
2) the video button will not generate a video for any event. the ''generate video' button is greyed out and underneath it always says 'No Video Files Found'. thanks for any help.
ps: I have trieed clearing cookies, made no difference. I've viewing zm in google chrome on a windows 10 pc
Re: event play button greyed out, always defaults to stop
1.34 is seriously old. Please update to at least 1.36, 1.37 is preferred if you are going to run on pi.
get newer releases from https://zmrepo.zoneminder.com
neuronetv
Post by neuronetv »
thanks but I am using the latest version thats available for me from the zmrepo
You need to the url in apt sources to the 1.36 repo or master. We do not auto-update between major releases.
neuronetv
Post by neuronetv »
ok thankyou but I'm struggling with this.
are you saying I need to locate the zmrepo file and update the url in it? I can't find any file named zmrepo
Follow the directions at https://zmrepo.zoneminder.com. The newer versions will just override the old ones.
neuronetv
Post by neuronetv »
thankyou and I'm still struggling a bit but at your link I saw there was a raspian image for a raspberry pi at the bottom of the page. I managed to get it up and running however that damn play button is still greyed out, it still defaults to stop and the event won't play unless I select 1x from the drop down list. aarrgghh
neuronetv
Post by neuronetv »
update:
I've managed to update zm 1.34 to 1.36 using the instructions I found here:
viewtopic.php?t=31740&sid=78e579a3142f6 ... 060205bf6d
but would you believe it the event play button is still greyed out and the web interface won't play an event at all now. before with 1.34 I could get the event to play by clicking the 'stop' drop down list and then clicking 1x but now even that won't work. I can't play back any event.
