Problems getting object detection work
zmki_jego
Post by zmki_jego »
Hello, I have installed zoneminder and event sever completely from scratch and according to official docs, i.e. did everything as described there. But for whatever reason and all that I‘ve tried I cannot get object detection to work in zoneminder. Opencv is properly installed and up and running. Doing object detection outside zoneminder with some sample scripts downloaded from the internet also works fine. But for whatever reason not yet in zoneminder. Could you please help me out solving it. That would be great. At the moment when I try object detection manually on the command line for a certain zoneminder event I get the following output, so something seems to be wrong with my installation?
Thanks a lot for your support.
root@nano:/home/jetson/zmeventnotification# sudo -u www-data /var/lib/zmeventnotification/bin/zm_detect.py --config /etc/zm/objectconfig.ini  --eventid 369 --monitorid 1 --debug
Unrecoverable error:future feature annotations is not defined (abstracts.py, line 33) Traceback:Traceback (most recent call last):
  File "/var/lib/zmeventnotification/bin/zm_detect.py", line 556, in <module>
    main_handler()
  File "/var/lib/zmeventnotification/bin/zm_detect.py", line 267, in main_handler
    log.init(name='zmesdetect_' + 'm' + args.get('monitorid'), override=g.config['pyzm_overrides'])
  File "/usr/local/lib/python3.6/dist-packages/pyzm/ZMLog.py", line 227, in init
    engine = create_engine(cstr, pool_recycle=3600)
  File "/usr/local/lib/python3.6/dist-packages/sqlalchemy/engine/__init__.py", line 525, in create_engine
    return strategy.create(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/sqlalchemy/engine/strategies.py", line 87, in create
    dbapi = dialect_cls.dbapi(**dbapi_args)
  File "/usr/local/lib/python3.6/dist-packages/sqlalchemy/dialects/mysql/mysqlconnector.py", line 135, in dbapi
    from mysql import connector
  File "/usr/local/lib/python3.6/dist-packages/mysql/connector/__init__.py", line 32, in <module>
    from .connection_cext import CMySQLConnection
  File "/usr/local/lib/python3.6/dist-packages/mysql/connector/connection_cext.py", line 40, in <module>
    from .abstracts import MySQLConnectionAbstract
  File "/usr/local/lib/python3.6/dist-packages/mysql/connector/abstracts.py", line 33
    from __future__ import annotations
SyntaxError: future feature annotations is not defined
Re: Problems getting object detection work
