Hi All,
I've managed to get an unbadged PTZ camera working great in zoneminder and run a script, via cron, that pans the camera every half hour at night to a new location. If I run the commands from the CLI everything works as I'd hope, but when run via the script I still get alarms.
The first command to disable the camera is :
sudo zmu -m 4 -D -U "User" -P "PASSWORD"
2nd command moves the camera:
sudo zmcontrol.pl --id=4 --command=presetGoto --preset=002 "could be 001, 002 etc"
3rd command re-enables the camera:
sudo zmu -m 4 -E -U "User" -P "PASSWORD"
I have also tried to achieve the same by switching profiles, then moving then switching back still get alarms.
Can anyone help please?
Stopping alarms when PTZ camera is moving
Re: Stopping alarms when PTZ camera is moving
I've been using get_zones.pl script I found here and running:
Get a list of zones:
get_zones.pl -s inactive -z <zone_name>
get_zones.pl -r
Hi BiloxiGeek,
Do you have a link to that script, I can't find it anywhere on my setup?
SOLVED
Answering my own question here. By putting a sleep 10 command before re-enabling the camera stops the alarms happening. Gives time for the movement to complete and settle (focus etc) before monitoring resumes.
Cheers
Cheers
Script is in this thread if you want to test it out, it doesn't seem to be part of ZM natively.
viewtopic.php?p=103513
