ZM not record any stream(create empty new events)
coconut
Post by coconut »
i have a problem with ZM 1.34.26 working few years at CentOS 7.
Today i discovered that zm not record properly videos from cameras, create many empty files (every named new event) and in logs show this "can't insert frames: out of range value for column 'id' at row 1"
This fault is caused by overflow in column "ID" at sql?
How to repair this? How reset value in column "ID"?
Re: ZM not record any stream(create empty new events)
Event Id was changed to a big int in 1.35.11. So update. 1.34 hasn't been supported for years.
coconut
Post by coconut »
Ok, straight update 1.34 to 1.36 at CentOS is safe?
