It shows no events, error in log, but I have event files
homebrewdude
Post by homebrewdude »
This is the error.
Seems like it is recording and keeping data, just not seeing the events.
1.37.47
Screenshot from 2023-11-22 07-09-52.png (92.93 KiB) Viewed 18694 times
Re: It shows no events, error in log, but I have event files
I believe there were a couple of 1.37.47 builds - are you sure you have the latest?
And what screen was this error on if so? If you have montage, the review should work, too. At least in my experience.
I have a machine that is generating those errors as well. It's on my todo list to look into.
homebrewdude
I believe I have the latest.
This is the Montage Review.
If I look in my zoneminder folder, I have files within the limits of my filter for age.
Screenshot from 2023-11-23 13-42-55.png (303.56 KiB) Viewed 18637 times
It stays "no event"? Is that the live view or after you select a time range? If after, the time cursor can be out of range.
Are you in mocord or modect?
I do get some of that from time to time, but not for more than a couple minutes, and just one or maybe two cameras, typically from a WiFi or power glitch. I'm in mocord.
homebrewdude
It's Mocord and I selected 8hour.
I also use ZmNinja. And it just gives an error "error retrieving Event List". And shows nothing.
OK. But do you see the cams live before you select 8 hour?
homebrewdude
I have had some zoneminder updates, and I thought it was fixed. But now I have this.
Live cameras look fine.
If I got to Montage it seems ok, but it almost makes zoneminder lock-up
Montage Review shows no events.
And I get this error in log when I select montage.
Screenshot from 2024-01-19 12-56-00.png (81.65 KiB) Viewed 16452 times
Generally that is caused by api not being correctly configured.
homebrewdude
Checking the status of mysql
systemctl status apache2 mysql --no-pager -l
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2024-01-20 22:42:58 EST; 15h ago
Docs: https://httpd.apache.org/docs/2.4/
Main PID: 1248 (apache2)
Tasks: 12 (limit: 38198)
Memory: 59.5M
CPU: 11.566s
CGroup: /system.slice/apache2.service
├─ 1248 /usr/sbin/apache2 -k start
├─ 23305 /usr/sbin/apache2 -k start
├─ 23308 /usr/sbin/apache2 -k start
├─ 23309 /usr/sbin/apache2 -k start
├─280805 /usr/sbin/apache2 -k start
├─280827 /usr/sbin/apache2 -k start
├─280844 /usr/sbin/apache2 -k start
├─280872 /usr/sbin/apache2 -k start
├─281403 /usr/sbin/apache2 -k start
├─281442 /usr/sbin/apache2 -k start
├─281469 /usr/sbin/apache2 -k start
└─282003 /usr/sbin/apache2 -k start
Jan 21 14:19:42 Basement web_php[280827]: 1/21/24, 2:19:42 PM EST.490773 web_js[280827].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[281442]: 1/21/24, 2:19:43 PM EST.467005 web_js[281442].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[281469]: 1/21/24, 2:19:43 PM EST.467459 web_js[281469].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[23305]: 1/21/24, 2:19:43 PM EST.467460 web_js[23305].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[280872]: 1/21/24, 2:19:43 PM EST.468153 web_js[280872].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[23308]: 1/21/24, 2:19:43 PM EST.469508 web_js[23308].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[280827]: 1/21/24, 2:19:43 PM EST.470300 web_js[280827].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[281442]: 1/21/24, 2:19:43 PM EST.471058 web_js[281442].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[23305]: 1/21/24, 2:19:43 PM EST.474045 web_js[23305].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
Jan 21 14:19:43 Basement web_php[281469]: 1/21/24, 2:19:43 PM EST.477740 web_js[281469].ERR [192.168.1.30] [There%20was%20an%20error%20-%20error()] at ?view=montagereview line
● mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2024-01-20 22:43:00 EST; 15h ago
Main PID: 1292 (mysqld)
Status: "Server is operational"
Tasks: 61 (limit: 38198)
Memory: 1.3G
CPU: 18min 15.371s
CGroup: /system.slice/mysql.service
└─1292 /usr/sbin/mysqld
homebrewdude
I ended up removing and reinstalling zoneminder. All good now.
