Warning: Division by zero in ...
pmeakins
Post by pmeakins »
I eventually got Zoneminder installed - much hassle, I created an installation script if anyone is interested. Let me know.
I have added a Fusion BT878A card - indeed card=77 works, apart from the issue of one controller chip and 4 outputs but thats another story.
I added two camera to Zoneminder and all looked fine, but when I click cycle and/or montage I get the following message:
Warning: Division by zero in /zoneminder/www/zm_html_view_montagefeed.php on line 50
Warning: Division by zero in /zoneminder/www/zm_html_view_montagefeed.php on line 51
Warning: Cannot modify header information - headers already sent by (output started at /zoneminder/www/zm_html_view_montagefeed.php:50) in /zoneminder/www/zm_html_view_montagefeed.php on line 60
Warning: Cannot modify header information - headers already sent by (output started at /zoneminder/www/zm_html_view_montagefeed.php:50) in /zoneminder/www/zm_html_view_montagefeed.php on line 61
Warning: Cannot modify header information - headers already sent by (output started at /zoneminder/www/zm_html_view_montagefeed.php:50) in /zoneminder/www/zm_html_view_montagefeed.php on line 62
Warning: Cannot modify header information - headers already sent by (output started at /zoneminder/www/zm_html_view_montagefeed.php:50) in /zoneminder/www/zm_html_view_montagefeed.php on line 63
Warning: Cannot modify header information - headers already sent by (output started at /zoneminder/www/zm_html_view_montagefeed.php:50) in /zoneminder/www/zm_html_view_montagefeed.php on line 64
Any ideas, I have come to a dead-end and am unable to proceed.
Any ideas.
Regards
Phil
zoneminder
Site Admin
Post by zoneminder »
The only way these division by zero errors could happen is if (a) you have defined one or more monitors without a width and height or (b) if there is some database problem that means empty results are being report. I would think (a) is more likely. Can you view streams etc of the monitors one at a time?
Phil
cordel
Post by cordel »
or possibly that you have not defined the montage monitor h+W in the options under the Web tab.
Make sure vaules for ZM_WEB_MONTAGE_WIDTH and ZM_WEB_MONTAGE_HEIGHT are present and suitable.
Regards,
Cordel
