The memory fills progressively
Re: The memory fills progressively
This is much larger, occupying gigs in a few hours. There are very few events and it only records when an event happens.
In the logs, there are a few of these errors:
Error writing packet: Invalid argument
And a few of these warnings:
Telemetry server returned HTTP POST error code: 301
Anything else to look for?
Regards,
Mark
Regards,
Mark
There's no server there at present, so turn off Options->Telemetry send checkbox.Telemetry server returned HTTP POST error code: 301
The Error writing packet: Invalid argument is very very bad. We need debug level 3 logs.
With zoneminder-1.37.50-1.86.20240126gitg543d3bdd9.fc39.x86_64, I still need to restart to free up memory every few hours. I am not seeing recent errors or warnings except for the telemetry server. I have not disabled that setting. Record durations also seem to be correct. It no longer gets any ONVIF events from my "problem" cameras. I expect they do not follow the standard correctly.
Regards,
Mark
Regards,
Mark
It doesn't handle sources that use this sort of theing in 1.36.x either...
rtsp://192.168.1.224/user=admin_password=passwd_channel=0_stream=1.sdp?real_stream
@dougmccrary what?
That's not a valid url. I went googling for the valid equivalent and found tons of problems on the way. Maybe tomorrow I can be of more assistance.
but the user= etc has to come after the ?
I'm pretty sure 1.36 supports cameras with those type of streams that one is just mistyped..
- borozenetsww
Work for me on last build.
rtsp://192.168.3.4:554/user=user_password=pass_channel=1_stream=0.sdp?real_stream
Sorry Isaac. I meant that that string works in 1.36, but not 1.37. But then 1.37 system broke, so don't worry about it for now.
I'm seeing the same issue on a system that's basically remained the same (in terms of camera and configuration) for a couple of years.
I'm currently running 1.37.50~20240129103951-jammy, and I can't really tell with which release it started happening, but server memory is slowly eaten up, moving onto swap being exhausted until there's an eventual OOM auto kill of zmc.
You can actually watch it happening in real time in htop, it's quite quick: Nothing of note in the default log output.
Hey, are people who are experiencing this using Decoding=OnDemand?
I think I found the problem, and it's because Analysis is waiting for decode and so capture thread is just filling up the queue.
new package building should fix this.
I am
Mine are set to Decoding = Always or None. The ones growing biggest are all for my cameras that don't do ONVIF events correctly.
Regards,
Mark
Well, it seems to have worked for me.
I upgraded to 1.37.50~20240130093217-jammy a couple of hours ago, and memory usage has stayed pretty constant since.
I don't know if you did something with this latest release, but I was able to get the source path on one line today.
The path in 1.36 is rtsp://192.168.1.218/user=admin_password=Buffy4@sdCA_channel=0_stream=1.sdp?real_stream
When I tried to paste it into 1.37, I got this: But now it's all on one line, and works.
BTW, I see what you did with the start-up delays. Working nicely here now.
The @ symbol is confusing it. It is illegal in a url. Must be % encoded.
