Can't add a monitor
Anna.N
Can't add a monitor
Post by Anna.N »
Fresh install of Zoneminder 1.37.53-20240224.12 on Debian 12 (Armbian 23.11.1 Bookworm)
When trying to add a monitor, the following error appears in the log and no monitor is added.
SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'ONVIF_Events_Path' in 'field list'', statement was 'INSERT INTO....
IgorA100
Re: Can't add a monitor
Post by IgorA100 »
You have a very recent version. I don't know where you found it :) In theory, it shouldn't have appeared yet.
This error is due to a change made yesterday: https://github.com/ZoneMinder/zoneminde ... 3841/files
It looks like column ONVIF_Events_Path was added to the update code, but forgot to add it for a clean installation.
New packages are building. 1.37.54 should have the necessary db updates to fix this.
Anna.N
Post by Anna.N »
Thanks, updated to 1.37.54, monitor successful added
Anna
NC_Hokie
Post by NC_Hokie »
I have just installed 1.37.55 on Ubuntu 20 (Focal) and am having this same issue as of Tues Feb 27 2024
