Clear log_debug_target or set it to _zmcontrol.pl, as we are not interested in zmc.
Clear
Hikvision PTZ control
Re: Hikvision PTZ control
Done that, I have also done a complete machine restart as there were some updates. I even cleared the log_debug_file and nothing discernible has appeared. I even did find . -mmin -20 to see all the files created within the last 20 mins but they all appeared to be the standard logging files.
root@cogen-main:/var/log# find . -mmin -20
./fail2ban.log
./syslog
./auth.log
./lastlog
./journal/3a087e415bc845c5a7342d185df69708/user-1000.journal
./journal/3a087e415bc845c5a7342d185df69708/user-1002.journal
./journal/3a087e415bc845c5a7342d185df69708/system.journal
./wtmp
./zm/zmc_m1.log
./zm/zmfilter_2.log
./zm/zmsystemctl.log
./zm/zmfilter_4.log
./zm/zmc_m3.log
./zm/zmcontrol_1.log
./zm/zmdc.log
./zm/zmpkg.log
./zm/zmfilter_1.log
./zm/zmupdate.log
./zm/zmstats.log
./zm/zmc_m2.log
./apache2/access.log
root@cogen-main:/var/log# cd zm
- Zoneminder2.png (88.33 KiB) Viewed 3825 times
After doing a tcpdump and analysing the traffic, along with finding a copy of the ISAPI manual I could see the reason it wasn't working is because I am an idiot. Thanks for your patience with this.
In control device I was putting the device name not the id of what I wanted to control. Once I set the control device to 1 it started moving, now I just need to fine tune the control values to make sure I get decent control, as well as resolving the Multiport through Nginx Proxy Manager issue I have
I can only assume you’ve not read this topic from the start, or some kind of AI(lol).
The offending post, now deleted, was an AI (actual idiocy) reword of iconnor's posting at
viewtopic.php?p=132774#p132774
