Linked Cameras Creating Events within Events
Burtski
Post by Burtski »
Looks like Linking is very broken.
No longer causing Seg faults but now they are creating 100's of events all at the same time.
2024-03-12 08_16_57-ZM - Events.png (98.13 KiB) Viewed 1576 times
Note the number of frames vs the size of the files and durration.
I am using Version: 1.37.55~20240310110432-focal
The log file has lots of:
2024-03-12 08_23_24-ZM - System Log.png (38.72 KiB) Viewed 1576 times
The low resolution monitors that these are linked to appear to work fine.
What are my next steps?
Burtski
Re: Linked Cameras Creating Events within Events
Post by Burtski »
Well I ended up reinstalling everything from scratch ( for non-ZM reasons ).
That appears to have done the trick. It all appears to be stable now.
I am guessing that all the fiddling just made a bigger mess.
I am still occasionally seeing overlapping events in the linked cameras.
When a linked camera is very near the end of an event and a trigger comes from a different linked camera, there may be a few seconds of overlap where when event it not finished recording but a new event has started.
This has never been more than 5 seconds, generally it is 1-2 seconds.
Definitely not a problem!
Running Version 1.37.56
10 Cameras, Each with one high resolution and one low resolution monitor.
Motion detection on all low resolution monitors.
All high resolution monitors are linked to all low resolution monitors.
