Web page controls layout and preset not working
iamnotme
Post by iamnotme »
My controls don't align properly and I don't think they ever have, and I seem to have lost the ability to set a preset since doing an update yesterday.
I use Firefox, and am currently on 123.0.1
My zoneminder installed version
apt-cache policy zoneminder
zoneminder:
  Installed: 1.37.55~20240315091333-jammy
  Candidate: 1.37.55~20240315091333-jammy
IgorA100
Re: Web page controls layout and preset not working
Post by IgorA100 »
I can't reproduce the problem yet :(
Did you clear the cache (Ctrl+R)?
What "Control Type" is set?
Are there any errors in browser console?
IgorA100
Post by IgorA100 »
I'm not 100% sure, but it should work:
Enable developer mode in the browser and remove 2 checkboxes (as in the picture) for the button control block.
IgorA100
Post by IgorA100 »
Check your browser's zoom setting.
It's probably less than 100%.
iamnotme
Post by iamnotme »
IgorA100 wrote: Tue Mar 19, 2024 7:10 pm Check your browser's zoom setting.
This was indeed the problem, thanks for the suggestion and taking time out to respond. It never even occurred to me and I don't remember changing the zoom level so must have been a long time ago.
The setting of presets is still broken though. I even updated this morning to see if anything had changed.
IgorA100
Post by IgorA100 »
iamnotme wrote: Fri Mar 22, 2024 8:07 am The setting of presets is still broken though. I even updated this morning to see if anything had changed.
What update do you currently have installed?
Problems with zooming in the browser and displaying the control panel have been fixed in version 1.37.56~20240321124416
If you have 1.37.56~20240321124416 installed, try clearing your browser cache.
If you still have a problem, don't hesitate to mention it. But at the moment I am unable to reproduce the problem.
What is your monitor resolution and what scale is set in your browser?
iamnotme
Post by iamnotme »
IgorA100 wrote: Fri Mar 22, 2024 8:38 am
Why would resolution and scale affect the SET button that was previously working? Everything else on the screen works now, even the reboot function worked. Camera PTZ functionality is fine, I just can't save presets like I used to be able to.
I updated again this morning and have tried it with Firefox as well as Vivaldi, which has never connected to Zoneminder. The SET button still doesn't bring up the pop up that it used to that would allow saving of presets. I'm not sure how the functionality works with the camera, but there are no packets sent to the camera when the SET button is pressed, so it may be that it doesn't send data until the preset is saved.
Current version:
zoneminder:
  Installed: 1.37.56~20240322163032-jammy
  Candidate: 1.37.56~20240322163032-jammy
IgorA100
Post by IgorA100 »
I just found out that the "SET" button does not work.
Yes, there is a problem. It's unclear why.
We will try to resolve it as soon as possible.
set button should work now.
iamnotme
Post by iamnotme »
IgorA100 wrote: Sat Mar 23, 2024 3:03 pm I just found out that the "SET" button does not work.
iconnor wrote: Sat Mar 23, 2024 5:39 pm set button should work now.
Thanks both for confirming and pushing a fix
