RLC-1212A black playback screen
i have an RLC-1212A and a RLC-1224A with ZM 1.36.33 on Debian.
The h265 Stream records fine. The live view works. But if i want to playback a Record, the Screen remains black.
Any Hints?
Any Hints?
Re: RLC-1212A black playback screen
Your browser, like most, does not like h.265. Test with h.264 and see if it works.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Already found that (and posted there).
I would, if it really helps...But probably means you'd need to get 1.37
Is there any Windows Browser that plays 265?
I think Chrome, but search browser hevc - there's a list.
Chrom(ium) is, what i use anyway...
Right. I was wrong...
So, with windows there is almost no chance
If i play with mjpeg i have a picture, but i cant scroll...
Is Edge any better?
As in you can't drag the progress bar? Or it's not there?If i play with mjpeg i have a picture, but i cant scroll...
Nope. Same behavior.
It begins to Play, if i want to scroll, the Progressbar jumps to the Point and the Progress shows the right Time, but the picture almost freezes at the Startingpoint.As in you can't drag the progress bar? Or it's not there?If i play with mjpeg i have a picture, but i cant scroll...
In Fact it plays with about 1/10 Rate.
When it reaches the time showed in the Progess, it plays at 1/1 Rate.
If i then jump backwards, it jumps there (i think).
OK, so sluggish, to be charitable?
This is with hevc only? Or do you even have some h264 cams to know?
yes
264 works fine in auto Mode (mp4). If i switch to mjpeg its the same as with 265.Or do you even have some h264 cams to know?
Hmm
Where? are you on 1.36.33 or .34?264 works fine in auto Mode (mp4). If i switch to mjpeg its the same as with 265.
as in post #1 1.36.33.
apt dosnt give a newer one.
