Upgrade from ZM 1.36 to 1.37
Re: Upgrade from ZM 1.36 to 1.37
1.37.x is is development, so docs come later.
1.37 just breaks out the various Function selections for finer control to match your needs. So
Low-Res stream with MoDect set
HiRes stream with NoDect set, triggered from Events on the LoRes stream
are spread across three pages:
Source->Decoding
Analysis->Motion Detection
Recording->Recording
Pick what you want in the dropdowns.
ckris
Post by ckris »
iconnor wrote: Mon Jan 08, 2024 3:18 pm Use packages at https://zmrepo.zoneminder.com
I still havn't figured out how to upgrade when running on Fedora 40 :oops:
guenni
Post by guenni »
I don't have a full html-view anymore after upgrade/new install of 1.37.64. Neither with firefox nor with chromium under debian12
<zmIP>/ZM looks like plain-text
Cleared the problem by myself by doing: apt remove --purge zoneminder and deleting all files and directories (including zm-db table) following the hints given by the --purge option. New install via 1.37 script did its job.
