Hi all,
I'm trying to improve mouvment detection in my house.
Since 2 year, i have installed zoneminder, camera and configure all.
Now, i'm trying to have a good mouvment detection (without fault alarm) not just monitor.
So, i can give my details but i'm not sure that are good !
It's possible to give me some advices ? Thanks a lot
-Reference Image Blend %ge : 6,25% (Indoor)
-Alarm Reference Image Blend %ge : 6,25%
-path : /video.cgi
-Resolution : 640*480
-deinterlacing : disabled
-storage area : default
-save jpegs : frames + analysis images (if available)
-video writer : disable
-Image Buffer Size (frames) : 50
-Maximum Image Buffer Size (frames) : 50
-Warmup Frames : 25
-Pre Event Image Count : 10
-Post Event Image Count : 10
-Stream Replay Image Buffer : 0
-Alarm Frame Count : 16
Estimated Ram Use Min: 52.75MB Max: 96.625MB
Improve motion detection
Re: Improve motion detection
I'm in this mode.
Remote (IP) cameras with jpeg mode only
You mean Remote Source Type? Unless you have an oddball setup you want ffmpeg source type.
So start with that, or explain more about your camera setup.
