I have created a new PPA which contains the latest stable release + fixes that will go in the next release. So that I can get some testing before release. Thing of it as release candidates builds.
So the current contents are what will go into 1.36.11
sudo add-apt-repository ppa:iconnor/zoneminder-proposed
New testing PPA
Re: New testing PPA
not replacing /dev/shm ?
Re: New testing PPA
What does /dev/shm have to do with anything?
Re: New testing PPA
In the present version 1.37.1, you (?) replaced it with:
- Screenshot from 2021-11-03 22-59-10.png (6.96 KiB) Viewed 37571 times
Re: New testing PPA
Yeah, that's 1.37.
This is a post in the 1.36 group about a testing ppa for 1.36 stable releases.
1.36 doesn't get new features. Just fixes.
Re: New testing PPA
Right. OK.
Re: New testing PPA
Had a problem installing on mint 20.2. A link wasn't created to Zoneminder.conf in conf-enabled. fixed with sudo a2enmod rewrite then created a link to zoneminder.conf and restarting apache2
Re: New testing PPA
Just pushed a bunch more fixes and some code to reduce ram use while recording.
I feel it needs a bit of testing before release. Please let me know if you see anything weird.
