LiveCD Puppy Linux ZM 1.30.2
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
UPDATE
Puppy Linux Tahr 6.0.5 operating system.
ZoneMinder has been upgraded from 1.30.1 to 130.2
Complete OS and working ZoneMinder as a LiveCD or install to USB drive or hard drive.
Link Updated 10/28/2021
Download Link
Download and burn to CD or install to HDD or USB drive. Zoneminder will run on boot...WAIT 2-3 minutes for the servers to start.
IMPORTANT --- ON FIRST RUN after installation, Let ZoneMinder start up. Then open a terminal and enter->
#zoneminder stop
#killall mysqld
#mysqld
close the terminal. Open a new terminal and
#zoneminder start
this is to ensure the MySQL server is on the correct Time. and event Export and Video generation and Stills view work.
Download link :[url=https://drive.google.com/open?id=0By2RU ... 181VlJDRzQ[/url]
in a browser http://localhost/zm
Runs completely in RAM as a LiveCD when burned to cd. Can be frugaly or full installed to HDD or USB drive. Use a save folder/file to save all settings in the frugal or RAM mode. Works well installed to USB.
ZoneMinder 1.30.2
Apache 2.4.7 (Ubuntu)
MySQL 5.5.35-1ubuntu1 - (Ubuntu)
PHP extension: mysql, curl, mbstring
PHP version: 5.5.9-1ubuntu4
phpmyadmin 4.6.5.2
phpmyadmin user = root
password = admin
change samba password
#smbpasswd -a root
All other passwords are "admin" or "woofwoof"
Good Luck!
illki
Re: LiveCD Puppy Linux ZM 1.30.2
Post by illki »
hi,
while booting from usb drive i got the following error
puppy_tahr_6.0.5.sts not found. Dropping out to initial-ramdisk console
i can see the file on the usb disk
tried burning iso with lilo, rufus, unetbootin, uneversal USB installer and so on
tried googling also but cannot find the solution that i can apply to this iso
can you help with this error?
Hello! I will look to see what is going on. can you burn a cd? just as reference as we see what is going wrong. I will test out a usb install again to get warmed up to solve this for you
kevaryza
Post by kevaryza »
Hello rockedge nice job, I could see everything was working very good but I got the following message when I tried to watch a new monitor: you have no permission to access dev/video0 or something like that, I appreciate your job and answer
greetings from Colombia
Kevin
change the permission on the camera like this:
open a console (terminal) and type ->
#chown www-data /dev/video*
or
#chown www-data /dev/video0
then open the monitor setup editor and save the camera setup again. This should fix it.
if you are interested you can update zoneminder from 1.30.2 to 1.30.4
I could give you a set of instructions to do it using the Puppy Package Manager. Takes a few minutes and several commands to change some permissions so they are correct.
illki
Post by illki »
rockedge wrote: Mon Jun 26, 2017 1:11 pm Hello! I will look to see what is going on. can you burn a cd? just as reference as we see what is going wrong. I will test out a usb install again to get warmed up to solve this for you
I will try to get usb cd drive and will reply here later
thanks
yes! let me know how it works for you. :D
mavi
Post by mavi »
Thanks for putting this up, will give it a shot.
holan
Post by holan »
Can update the download link please.
Thanks in advance
