I'd like to set ZM with combozola so it would use ONLY port 80, also for cambozola streaming. How can I configure ZM this way ?
Thank you,
Darko
Web server + streaming over port 80 only
- zoneminder
- Site Admin
- Contact:
Re: Web server + streaming over port 80 only
Hi Darko,
I'm not sure I understand you. AFAIK it does only use port 80 for all access. Cambozola just writes back after a http request I think. Can you explain further?
Phil,
Phil,
yes it uses port 80.. only
if you put a firewall, router, ect.. and only leaves port 80 TCP zm will work fine.
Thank you both.
Guess you're right, but from our company we cannot access the ZM machine. We're using proxy server on 8080 port and the ZM machine is on some other static ADSL IP. I can access it from home but not from our company. I'll need to take a look at this closely. Perhaps we have some sort of traffic filtering.
Bye,
Darko
Bye,
Darko
