ZM Version 1.36.33. For a lack of a better title, pretty much that. I setup Zoneminder and it was up and running with the database on a separate VM, ZM in its own VM with a NFS share to a ZFS pool to record footage to. There are about 45 cameras, with all set to permanently record as that was the only way I was able to get the footage decent enough without causing too much overhead.
However, now some recordings aren't working properly, or some events are running over 6 hours in length but only 10 frames from that, when they should be 10mins in length. Which sometimes it has both the 6hr 10frame event, and the regular 10min event that works and records properly.
I'll gladly post any logs and settings and the such, we are a business running 24/7 5-6 days a week, we mainly just use it to review past footage, rarely ever live but occasionally the need arises.
Zoneminder was working for a while, but has been struggling
- Second monitor with no working footage
- Screenshot_2.jpg (96.01 KiB) Viewed 2852 times
- One monitor that has "working" footage
- Screenshot_1.jpg (96.15 KiB) Viewed 2854 times
