Zoneminder 1.37.61
Ubuntu 20.04.6 LTS (focal)
I've been having a "floating point exception" error filling my /var/log/zm filesystem logs. The error repeats about every 1/2 millisecond and creates log files that are over 7Gb per day. Strangely, zoneminder seems to be working even when these errors are active. See the repeating error below from zm_m2.log.
06/19/24 00:01:48.727562 zmc_m2[143175].ERR-zm_signal.cpp/50 [Got signal 8 (Floating point exception), crashing]
06/19/24 00:01:48.727601 zmc_m2[143175].ERR-zm_signal.cpp/82 [Signal address is 0x56147017ac47, from 0x56147017ac47]
06/19/24 00:01:48.727856 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100ac9) [0x5614701f7ac9]]
06/19/24 00:01:48.727870 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f6ecbeaa420]]
06/19/24 00:01:48.727880 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0x83c47) [0x56147017ac47]]
06/19/24 00:01:48.727889 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 3: /usr/bin/zmc(+0x1cc4b1) [0x5614702c34b1]]
06/19/24 00:01:48.727898 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f6ecb562df4]]
06/19/24 00:01:48.727906 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f6ecbe9e609]]
06/19/24 00:01:48.727915 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f6ecb24d353]]
06/19/24 00:01:48.727923 zmc_m2[143175].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
06/19/24 00:01:48.727932 zmc_m2[143175].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
06/19/24 00:01:48.727940 zmc_m2[143175].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100ac9 0x83c47 0x1cc4b1]
06/19/24 00:01:48.727954 zmc_m2[143175].ERR-zm_signal.cpp/50 [Got signal 8 (Floating point exception), crashing]
06/19/24 00:01:48.727963 zmc_m2[143175].ERR-zm_signal.cpp/82 [Signal address is 0x56147017ac47, from 0x56147017ac47]
06/19/24 00:01:48.728098 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100ac9) [0x5614701f7ac9]]
06/19/24 00:01:48.728109 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f6ecbeaa420]]
06/19/24 00:01:48.728117 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0x83c47) [0x56147017ac47]]
06/19/24 00:01:48.728126 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 3: /usr/bin/zmc(+0x1cc4b1) [0x5614702c34b1]]
06/19/24 00:01:48.728135 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f6ecb562df4]]
06/19/24 00:01:48.728144 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f6ecbe9e609]]
06/19/24 00:01:48.728152 zmc_m2[143175].ERR-zm_signal.cpp/108 [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f6ecb24d353]]
06/19/24 00:01:48.728161 zmc_m2[143175].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
06/19/24 00:01:48.728169 zmc_m2[143175].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
06/19/24 00:01:48.728177 zmc_m2[143175].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100ac9 0x83c47 0x1cc4b1]
06/19/24 00:01:48.728188 zmc_m2[143175].ERR-zm_signal.cpp/50 [Got signal 8 (Floating point exception), crashing]
Here is the output from "addr2line -Cfip -e /usr/bin/zmc 0x100ac9 0x83c47 0x1cc4b1"
void std::vector<char, std::allocator<char> >::_M_realloc_insert<char>(__gnu_cxx::__normal_iterator<char*, std::vector<char, std::allocator<char> > >, char&&) at ??:?
std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > std::operator+<char, std::char_traits<char>, std::allocator<char> >(char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) at ??:?
soap_getfault(soap*) at ??:?
Doug
