I was trying to figure out where to put this, mobile did not seem the place. I see several under 1.36.x (which I am running) so here goes. Using 1.36.x just fine. Prefer ZMNinja Desktop for the remote viewing locations. But there is an issue that just never seems to go away with ZMNinja, after setting the columns to 5 it works just fine most of the time (more later), but on next startup, it has revered to two columns. I have tried to figure out what is going on. Presently running on Ubuntu Mate 22.04. I am trying to simplify the remote monitor startup as much as possible. If ZMNinja would just start up with the proper column setting it would be great.
Another thing happens at times and that is after running it will jump back to 2 columns again. I believe this may occur when one of the cameras goes from mocord to record (done by a cron job.
So will say use Montage more but I have found that ZMN demands less of the ZM server than using Montage. (even though we have plenty of horsepower left just prefer to do anything to keep load down)
OS ZM server: Ubuntu 22.04 server
OS for ZMNinja desktop: Mate 22.04
ZMNinja Rev: zmninja-pro-1.6.9-linux-x86_64.AppImage*
